    Make Mountain Script ?
    5 Posts 2 Posters 602 Views 2 Watching
    • david57D
      david57
      I found a rock at Google WareHouse. Is there a script that will create hills or mountains like this: http://sketchup.google.com/3dwarehouse/details?mid=55086cf62f5f0dfdf5e58ea4049d8efc&prevstart=48
        Try Greble2 by Chris Fullmer or Protrude by Jim Foltz
        Not exactly that you want but...you can make something πŸ˜‰
        PS As Divide from Protrude works only on rectangle, use Zorro2 by Whaat for divide your first surfaces πŸ˜‰
        • david57D
          david57
          Thanks Frenchy. I didnt know this scripts existed, I need to try them out and see if i can make something that will work or cut some time.
          • david57D
            david57
            Ok, i have to learn all of this.
              With the Zorro2
              you can make something here manually but if you use Projection by Didier Bur you will have the multiple Push Pull with random !
              Put negative number if the faces are White πŸ˜„
              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45696&stc=1&d=1224438362
