    How can import and locate the components by ruby script?
    4 Posts 2 Posters 1.3k Views 2 Watching
    • W Offline
      winzard
      Everyboby ,I want to have the method relating to import and location of the components.Please give me help .Thanks!
        Use the .load or .load_from_url methods from the DefinitionList to import components to the model. http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/definitionlist.html
        Depending how you want to add the component, use either entities.add_instance http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_instance or model.place_component http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#place_component
          If you want to get the path a component was loaded from use the .pathmethod for the definition. http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/componentdefinition.html#path
          • W Offline
            winzard
            The information is vrey important .And I want to import some components into coordinates by ruby scripts and locate the components by parameter form the user,What methods need to refer? Please give me some suggestions.Thanks!
            The size of components add a lot of difficulties,because space of the components need to taken in my ruby script.Now ,I have trouble to deal with that. Does some solutions be gave?
