    Detect a Dimmension object without .typename
    22 Posts 7 Posters 920 Views 7 Watching
      Regarding this findings on the speed of .typename: http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&start=0&st=0&sk=t&sd=a#p162235
      Is it possible to find out if an Entity is a DimensionLinear or DimensionRadial without using .typename?
        remus
        i remember jim mentioning duck typing, which looks something like this: if e.repspond_to? "some_method_unique_to_dimensions" then ...
        ive never really tried it myself, though, so you'll probably have to do some fiddling to get it to work.
          Problem is that dimensions aren't exposed to the API...
            remus
            There goes that cunning plan then.
            • tbdT Offline
              tbd
              on a 100 lines each with a dimension
              0.003
              Sketchup.active_model.entities.reject {|x| x.class==Sketchup;;Drawingelement}
              0.007 - 0.014
              Sketchup.active_model.entities.reject {|x| x.typename=="DimensionLinear"}
              SketchUp Ruby Consultant | Podium 1.x developer
              http://plugins.ro
                AlexMozg
                Сompromise decision, at the proper time to use both methods:
                class Sketchup;;Entity
                   def is_a_type?(t)
                      t.is_a?(String) ? (self.typename == t) ; self.is_a?(t)
                😉 Multiplying speed in ~1.5-2 times
                  0.003
                  0.007 - 0.014
                  Problem is, DimensionRadial is also a Sketchup::Drawingelement.
                  What I'm doing now is do a entity.kind_of?(Sketchup::Drawingelement) && entity.typename == "DimensionLinear"
                  That way the slow type checking is only used when there's a potential it's a dimension object.
                  • AdamBA Offline
                    AdamB
                    ..and you know for certain Ruby evaluates left to right?
                      erhh..? no... I just assumed it did. ..it doesn't?
                        I actually thought all scripting/programming languages evaluated left to right. That short-circut logic as a fundamental design.
                        • tbdT Offline
                          tbd
                          it evaluates left side, then right side and then the operation between.
                          here is an example:
                          1==1 && (p "me too";true)
                          => true
                          so in your example you will not see any speed improvement 😞
                          http://plugins.ro
                            I didn't understand that example. But I did a test:
                            def always_return_false
                            	puts 'call always_return_false'
                            	return false
                            def always_return_true
                            	puts 'call always_return_true'
                            	return true
                            def test1
                            	if always_return_false && always_return_false
                            def test2
                            	if always_return_true && always_return_true
                            When I run the code:
                            >> test1
                            nil
                            >> test2
                            nil
                            In the first case when the first check returns false it doesn't trigger the second check. I can't understand anything else than .kind_of? would do the same.
                            • tbdT Offline
                              tbd
                              my mistake, i was wrong. if left side is false the right side doesn't get evaluated
                              http://plugins.ro
                                Jim
                                This is my understanding also, but watch because the and operator is not the same as &&. I don't think and will shortcut.
                                  I did two more tests for this:
                                  def test3
                                  	if always_return_false and always_return_false
                                  def test4
                                  	if always_return_true and always_return_true
                                  Results:
                                  >> test3
                                  nil
                                  >> test4
                                  nil
                                    Found what the difference between and and && is:
                                    The binary "and" operator will return the logical conjunction of its two operands. It is the same as "&&" but with a lower precedence
                                    • AdamBA Offline
                                      AdamB
                                      Well that explains something that I've been bitten by a few times..
                                      mask = mask or object.getmask
                                      assigns mask to itself and ors with the results of object.getmask()!! 😮
                                      I end up having to do:
                                      mask = (mask or object.getmask)
                                      What kind of madman would introduce such an operator?
                                      Actually the one that beats all for sheer insanity is ruby.h #define-ing fopen() to be something completely different calling some Ruby thing. What the!, Argggh...
                                      I've got some harsh language for Mr.Ruby when/if I meet him.
                                      Adam
                                        I think I've always used && and || so I've avoided such problems. But I have had unexpected behaviour when I used not instead of !. I used not some times simply because I thought it was the same thing - but not would read better.
                                        Looking at the table of Operator Precedence I can see how it all fits together now. http://www.techotopia.com/index.php/Ruby_Operator_Precedence
                                        • AdamBA Offline
                                          AdamB
                                          Sure, it lists them out.
                                          But I see absolutely no compelling reason to have "Logical AND" differing from "Logical composition" wrt precedence.
                                          What is the 'use case' for the 2 forms? Does anyone know?
                                          Adam
                                          • tbdT Offline
                                            tbd
                                            maybe to play jokes like this :
                                            myvar = true and false
                                            => false
                                            myvar
                                            => true
                                            http://plugins.ro
                                            • 1 / 2
