    Detect a Dimmension object without .typename
    22 Posts 7 Posters 1.4k Views 7 Watching
      I actually thought all scripting/programming languages evaluated left to right. That short-circut logic as a fundamental design.
      • tbdT Offline
        tbd
        it evaluates left side, then right side and then the operation between.
        here is an example:
        1==1 && (p "me too";true)
        => true
        so in your example you will not see any speed improvement ๐Ÿ˜ž
        http://plugins.ro
          I didn't understand that example. But I did a test:
          def always_return_false
          	puts 'call always_return_false'
          	return false
          def always_return_true
          	puts 'call always_return_true'
          	return true
          def test1
          	if always_return_false && always_return_false
          def test2
          	if always_return_true && always_return_true
          When I run the code:
          >> test1
          nil
          >> test2
          nil
          In the first case when the first check returns false it doesn't trigger the second check. I can't understand anything else than .kind_of? would do the same.
          • tbdT Offline
            tbd
            my mistake, i was wrong. if left side is false the right side doesn't get evaluated
            http://plugins.ro
              Jim
              This is my understanding also, but watch because the and operator is not the same as &&. I don't think and will shortcut.
                I did two more tests for this:
                def test3
                	if always_return_false and always_return_false
                def test4
                	if always_return_true and always_return_true
                Results:
                >> test3
                nil
                >> test4
                nil
                  Found what the difference between and and && is:
                  The binary "and" operator will return the logical conjunction of its two operands. It is the same as "&&" but with a lower precedence
                  • AdamBA Offline
                    AdamB
                    Well that explains something that I've been bitten by a few times..
                    mask = mask or object.getmask
                    assigns mask to itself and ors with the results of object.getmask()!! ๐Ÿ˜ฎ
                    I end up having to do:
                    mask = (mask or object.getmask)
                    What kind of madman would introduce such an operator?
                    Actually the one that beats all for sheer insanity is ruby.h #define-ing fopen() to be something completely different calling some Ruby thing. What the!, Argggh...
                    I've got some harsh language for Mr.Ruby when/if I meet him.
                    Adam
                      I think I've always used && and || so I've avoided such problems. But I have had unexpected behaviour when I used not instead of !. I used not some times simply because I thought it was the same thing - but not would read better.
                      Looking at the table of Operator Precedence I can see how it all fits together now. http://www.techotopia.com/index.php/Ruby_Operator_Precedence
                      • AdamBA Offline
                        AdamB
                        Sure, it lists them out.
                        But I see absolutely no compelling reason to have "Logical AND" differing from "Logical composition" wrt precedence.
                        What is the 'use case' for the 2 forms? Does anyone know?
                        Adam
                        • tbdT Offline
                          tbd
                          maybe to play jokes like this :
                          myvar = true and false
                          => false
                          myvar
                          => true
                          http://plugins.ro
                            RickW
                            But now you know you can use
                            mask = mask || object.getmask
                            It saves typing the parentheses... (FWIW)
                            RickW
                            www.smustard.com
                              Saves you typing even more if you type mask ||= object.getmask ๐Ÿ˜‰
