    Podium Photomatch (AGAIN!) [TUTORIAL]
    31 Posts 14 Posters 7.1k Views 14 Watching
    • olisheaO Offline
      olishea
      Here's another photomatch I've been working on for a proposed surgery.
      I matched the model to one of the photos which make up the panoramic then rendered in podium.
      Here is my workflow:
      Original image in SketchUp
      http://i654.photobucket.com/albums/uu269/olishea/Picture19.png
      Match model perspective with photo
      http://i654.photobucket.com/albums/uu269/olishea/Picture17.png
      Building perspective matched, ready to render
      http://i654.photobucket.com/albums/uu269/olishea/Picture18.png
      Podium Render
      http://i654.photobucket.com/albums/uu269/olishea/20090528160447_5m34s.jpg
      Podium Mask
      http://i654.photobucket.com/albums/uu269/olishea/20090528145051_2m21s.jpg
      Podium render resized to fit panoramic
      http://i654.photobucket.com/albums/uu269/olishea/panopodium-1.jpg
      Podium render applied to panoramic in photoshop
      http://i654.photobucket.com/albums/uu269/olishea/panobluetest.jpg
      Final image
      http://i654.photobucket.com/albums/uu269/olishea/panobluetest-5.jpg
      oli
        I am a bit stumped at what is what here (although I'm pretty sure I'm seeing some very cool thing again - just don't know what) 😳
        Could you show and original and a final together?
        • marked001M Offline
          marked001
          blends really nicely... you're going to become the sketchucation master at this...haha... wish it somehow stood out a tiny bit more though... maybe blends a little too much... is that contradictory? haha...
          http://www.revision21vis.com
          instagram: revi21on
          • olisheaO Offline
            olishea
            haha I know what you mean. Although getting it to blend in is what my boss requires, you know the drill! The last thing we want is a building that distracts from the canal/listed mills etc. thanks for the comments
            oli
              sepo
              Looks good Oli...good old British weather. Even when sunny looks grey πŸ˜‰
                dylan
                Nice work oli.
                The last stiched image you posted, how did you get it to the improved panoramic version?
                Im guessing the last image is what the software turns out that you used to stich the pics together. Did you just crop from there?
                I would be interested in how you get the panoramic image and which software you use.
                http://dmdarchitecture.co.uk/
                • olisheaO Offline
                  olishea
                  Hi Dylan,
                  I just used the automate function in Photoshop. (file>automate>photomerge)
                  It will only work well if the original photographs run into each other nicely (and the daylight doesn't change between each photo you take, as with mine)
                  It is worth playing around with the stitching modes (perspective, cylindrical etc.) to best suit your image. I then cropped it and blurred/clone stamped the stitches.
                  There are other ways of doing this with perfect results but I find this method quickest.
                  oli
                  • olisheaO Offline
                    olishea
                    Here is another version....nicer I think.
                    marked.....I get you now, it can blend in while still having contrast.
                    http://i654.photobucket.com/albums/uu269/olishea/panobluetest-4.jpg
                    oli
                      Thanks for the "originals". Indeed they were needed to make the whole situation clear. Really great work. And I don't mind the blending either. I guess that's also the goal (somewhat); to convince officials for instance that it won't be striking at all.
                      • soloS Offline
                        solo
                        Oli
                        You seem to have made a point in mastering this whole photo-match thing...well done!
                        I have never really had a need for this in the past, but recently I've had a call for a few of these, I use a whole different technique and software to achieve what I was asked for however you seem to have a very much easier and quicker solution (so it looks), do you think if and when you get a chance that you would be willing to throw a quick tutorial or even video together on the basics of your technique? It would certainly be something we would add to our growing anthology of tutorials and something that will benefit many users, myself included.
                        http://www.solos-art.com
                        • olisheaO Offline
                          olishea
                          Solo.....of course I will. I've learnt a wealth of information from your works and tutorials so I'd be more than happy to return the favour! I'm kinda flattered that you, render god, can learn something from a mere mortal like me!
                          (and yes the technique is easy)
                          Watch this space.........
                          oli
                          • olisheaO Offline
                            olishea
                            yessir......
                            Here is the original photo before the building was applied: (I updated the first post too)
                            I would post an non-edited panoramic without the building but the image is flat now, sorry!
                            [edit] Here is the original panoramic before I stitched it better, without the building. Do you get it now?
                            http://i654.photobucket.com/albums/uu269/olishea/pano-original.jpg
                            oli
                              dylan
                              I must admit I always use more complicated ways of doing this. Your way Oli using Photomatch makes far more sense, seems very accurate and will save time.
                              Look forward to your tutorial, although what you have already posted is a very big help πŸ‘
                              • olisheaO Offline
                                olishea
                                The results can be amazing if you start off with the right photos. When I took my pics the sun went in and out of cloud....you can see the change in tone between the 5 photos which make this image up. (I also didnt use a tripod haha) I'm really not that good at photoshop otherwise I would have tried to make it completely seamless, maybe next time!
                                oli
                                • RichardR Offline
                                  Richard
                                  Mate awesome work again! I knew I was on to something when I said in another thread that I needed to watch your threads!!!!
                                  BUILTBRAND.COM.AU
                                  • olisheaO Offline
                                    olishea
                                    I dont know why you are impressed Richard, your work infinitely cacks all over this!!
                                    oli
                                    • RichardR Offline
                                      Richard
                                      Why????
                                      Because you've shown some great artistic merit, true mastery over your applications and proof of simplicity in approach!!! All impress me mate!
                                      BUILTBRAND.COM.AU
                                      • majidM Offline
                                        majid
                                        nice and mastee piece of work πŸ‘
                                        • olisheaO Offline
                                          olishea
                                          thanks guys! πŸ‘
                                          oli
                                          • holmes1977H Offline
                                            holmes1977
                                            Well done
                                            You have inspired me to give it a crack
                                            Exaggeration makes a dull story better.
                                            • 1 / 2
