    [Plugin] Extended Standard Views - ArchTools-version!
    11 Posts 10 Posters 16.9k Views 10 Watching
      AlexMozg
      My variant of script of published before Chris Fullmer.
      (http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19168)
      A difference is more correct code, to my mind.
      Includes: Iso Auto, Iso SW, Iso SE, Iso NE, Iso NW
      (Iso SW, Iso SE, Iso NE, Iso NW - only in menu)
      NOTE: Only correct works with SketchUp version 7
      It is the cut out part from my complex of plugins.
      Use and enjoy. 😉
      Extended Standard Views(ArchTools version)
      • P Offline
        putnik
        Thanks Alex! I havn't tried Chris's ruby, but yours works very well. Спасибо
        http://keshas.info
          bianhai
          Thanks to share!
          .jpg
          • G Offline
            gavvy
            👎 bianhai ,why your web always sell other people's sketchup script
              caddict
              thanks - real life-saver!
              • free agentF Offline
                free agent
                Hey can someone please fix this? I need plan view to realign with new axis, which doesnt work with align view in context click 😞
                • ArcA Offline
                  Arc
                  You can use JHS standard toolbar 2017, it is fixed.
                    babak
                    It's working flawlessly in Sketchup 2017 !
                    You will have to convert the script file AT_set_standard_views.rb to UTF-8-BOM (without BOM) first, otherwise it won't load properly in 2017.
                    How to do such a thing ?
                    1. Unzip the AT_set_standard_views.ziparchive (link above in AlexM's post. Registration is free in case you are not registered).
                    http://i.imgur.com/YCOIgc9.jpg
                    1. Open the freeware editor Notepad++ and download it if you don't have it.
                    2. Load AT_set_standard_views.rb go to menu "Encoding" and click "Convert to UTF-8-BOM (whithout BOM)."
                    http://i.imgur.com/ya1V3r0.jpg
                    http://i.imgur.com/tBGzNgF.jpg
                    1. Save the file and exit
                      There is a slight unzoom factor of .95 line 59.
                    http://i.imgur.com/qV9TB90.jpg
                    I turned mine back to 1 (without AlexM's permission...).
                    4. Put the new saved file with its folder "ArchTools" into your sketchup 2017 Plugins directory %appdata%\SketchUp\SketchUp 2017\SketchUp\Plugins.
                    Copy and paste this blue text in your Explorer Address Bar if you don't know where to find it.
                    Reload Sketchup 2017 and enjoy your new extension.
                    There is an AT view submenu in the "Camera" menu and a nice toolbar shown in AlexM's post.
                    A life saver for all those who where relying daily on Chris Fullmer's CLF Extended Views plugin until 2017...
                    Many thanks to AlexM !
                    • Bob JamesB Offline
                      Bob James
                      It's not as colorful as the ArchTools version but clf_extended_views.rb works just fine in SU Pro 2017 and Win10
                      clf_extended_views.rb in win10
                        ronhiatt
                        MANY THANKS! to AlexMozg for the Extended Standard Views!
                        AND to babak for instructions on installing it in SU 2017!
                        I became dependent on Chris Fullmer's version but lost it with SU 2017. My arrow keys are shortcuts to it.
                        BTW I tried changing the scale to 1, but that didn't work for me. I imagine it has to be formatted as 1.0 or something.
                        AGAIN thanks a bunch!
                        Ron
                          ronhiatt
                          This is a GREAT plug in! By the way the only way I know to install it is to copy the AT_set_standard_views.rb file to the Plugins folder.
