    Modifying Joint Geometry
    6 Posts 5 Posters 766 Views 5 Watching
    • P Offline
      Physicsguy1
      How would i go about changing a joint's geometry and appearance? Or texture?
        CPhillips
        Open the group and do whatever you want. As long as you dont change the axis the joint should still work as expected.
        • H Offline
          hobbnob
          basicly keep double clicking it until you get it's faces and edges, then just edit them. you need to go into the joints folder to edit them directly.
          My WIP Thread:Here
            MrPlanet
            What would happen if i changed the axis πŸ˜‰
            I reject your reality and substitute my own.
              JaViXP
              If you change the axis probably it would work in another axis.
              "Giving up is way harder than trying"
              JaViXP's Rendering
                CPhillips
                It will change the pivot direction of the joint.
