    Loft questions
    26 Posts 9 Posters 4.5k Views 9 Watching
    • Chris FullmerC Offline
      Well, just one for now. Maybe more to come later.
      In other programs, when you do a loft, can your original splines be non-planer with thmselves? I don't mean do they have to lie on the red/gree/blue axis. I mean truly and entirely non-planar. Or are you required to make all splines be planar with themselves. Does that make sense?
      Chris
      All my Plugins I've written
        Daniel S
        I donΒ΄t understand well the question.
        Here i attach an example. Can you make the lines and put the .skp file here? So I can make the loft and show you the result.
        Daniel S
        Loft.skp
          remus
          As pilou says, generally the curves can have any alignment relative to each other.
            Curves can be anything! πŸ˜‰
              Ahh, that totally answers my question. Yes, those splines are not planar. Interesting.
              Can you do a loft with only 2 spline instead of three? Maybe if you could just loft everything in the attached model? That would be helpful! Thanks,
              Chris
              Loft tests1.skp
                ok, I see frenchy's post using just 2 splines. i'd still like to see what type of surface is created by lofting the simple curves in the model.
                What I am trying to figure out is how to decide where to place the bezier curve "handles" that help guide the flow from one spline to the next. On just 2 splines I haven't been able to think of an acceptable solution, because the handles often just end up exactly between the start point and end point, and then there is no real bezier curving going on. Its just a straight line connection.
                So i'ld like to see how other software are handling only 2 splines. Non planar is now a whole new monster to deal with πŸ˜„
                Chris
                • soloS Offline
                  solo
                  That would be an awesome SU addition, you think it may be possible?
                  http://www.solos-art.com
                    Daniel S
                    Chris
                    Here i attach the results.
                    If you need more send me the .skp.
                    Daniel S
                    Loft tests1 results.zip
                      Number can be any πŸ˜‰
                      Ps Where is the plug for test your curves?
                        remus
                        Heres a few pics of how MoI treats the provided examples.
                        cf_loft.zip
                          @Solo, yes Its totally possible. I have a working protoype, but its incredibly stupid at this point. I've got a lot of coding to add to it to make it smart enough to work regularly. The biggest tasks ahead are re-ordering the points in the splines so that they are in order from start to end, then figuring out how place the handles.
                          Other than that, the actual surface maker is working very well. Its just hard to feed it use-able points.
                          Chris
                          • soloS Offline
                            solo
                            um...all sounds Greek to me, a "yes it's possible 'cos I'm a great ruby geek" would have been sufficient.
                            Very cool, this will add to my bunch'o fantabulous tools y'all code-jockeys have been so kind to make for us. πŸ‘
                              here an example of 2 no planar curves
                              (it's nurbs curves but I believe that is the same for beziers curves πŸ˜‰
                              Generally "start/end" of the closed curve it the point were the curve is closed πŸ˜‰
                              here at 15 h 15 O'Clock πŸ˜„
                                Goodness, and I thought the forums were a little slow today....I guess you just gotta ask the right question!
                                well, I've got an idea of how to proceed now. Thanks very much for the models and image everyone. I see now that some of what is going on is not as hard as I had thought. Of course, some of it is significantly harder....so I guess it all balances out.
                                Still working...
                                Chris
                                  ok, I've got it working well as long as each spline has the same amount of segments. And it doesn't really smooth out the mesh over 3 splines. I'll see if I can get one or both of those figured out tonight and maybe post a test version of the script in the next 24 hours. Thanks for everyone's help!
                                  Chris
                                  • EarthMoverE Offline
                                    EarthMover
                                    Chris,
                                    It might be worth also looking at how 3ds Max handles lofting. Although it only uses 2D splines, there are some parameter adjustments in the modifier panel that would be interesting to explore and possibly adapt into sketchup functionality, particularly the "fit" option. These two loft tutorials show pretty well how it works and they give a glimpse into the loft modifier rollout panel. Let me know if you want me to take some screen shots of all the Max lofting parameters.
                                    http://www.hallofheads.com/tutorials/tut7.htm
                                    http://tutorialscentral.com/index.php?option=com_content&task=view&id=33
                                    I don't know that you could ever push sketchup to do the kind of lofting that a nurbs modeler like Moi can do, but then again, you ruby geniuses always seem to amaze me.
                                    Content Creator at Skapeup
                                      Thanks for the links Adam. I've tried to use the loft tool in 3dsmax and I've done basic lofting with it. But that what you showed is very advanced. Probably out of the scope of what I think I'll ever be able to implement. But perhaps simplified versions of that could sneak into scripts. But I suppose I would have to understand how that stuff works in order to implement it.....
                                      Chris
                                        What is the difference between your future Loft Plug and the Sandbox "From Scratch"?
                                          From scratch essentially just draws straight lines between the curves (contours).
                                          Curve stitcher is also similar to this loft script.
                                          My loft will (theoretically) draw bezier curves between the curves. But with just 2 curves, there is realy no way to set up a bezier curve. But with 3 or more it should/will work great.
                                          And on top of that, my script will adjust for curves with varying segment counts, hopefully work with closed and open curves, and it lets you control how many segments are created between each segment.
                                          Here's a video. I was planning on releaseing something tonight, but I've gotta go to bed instead. I'll try to release this tomorrow. (it might take a long time to load, so just keep waiting for a bit....sorry)
                                          This video is not for the faint of heart - 22mb and 3+ minutes of no sound. It sort of shows how "from contours", curve stitcher, and loft compare. But again, my loft tool has a few more key features to add.
                                          [flash=793,643:27hg2omq]http://www.chrisfullmer.com/forums/loft_test.swf[/flash:27hg2omq]
                                          Chris
                                            Sweet! The curtain shape looks really nice.
                                            No sleep for you!! Get some caffeine and get back to work! ...pleeeeease... πŸ˜‰
                                            • 1 / 2
