    [Plugin] QHull
    51 Posts 20 Posters 57.8k Views 20 Watching
    • 2 Offline
      22curious
      Here's that skp. I think. ๐Ÿ’š
      Ex_LSystemPOINTS_QhullStall.skp
      Inspiration and texture
      • qwertyasQ Offline
        qwertyas
        to make it work on VISTA, WINDOWS 7 run SKETCHUP AS ADMINISTRATOR
        step by step:
        1 rightclick on sketchup icon
        2 select run as administrator
        3 agree to yellow popup window
        sketchup will start
        to get flat voronoi net:
        1. create some points (use projections plugin) they will be created on xy plane
        2. select all points and convert to group
        3. select group and copy vertical (no matter how high you place copy)
        now you have two identical groups of points one above the second
        1. select both groups
        2. select menu plugins>qhull>voronoi> selection free
        the voronoi tesselation will show up between point selections
        done!
        works for me, I hope will work for you ๐Ÿ˜„
          dbalex
          thanks avariant for the plugin and thanks qwertyas for the workflow! it works perfectly!
          http://www.bocostudio.com
            One has to find all the exe files that comes with the plugin, right click the files -> Properties and press the Unblock button. This is because Windows blocks executables downloaded from the internet.
            • bigstickB Offline
              bigstick
              Any chance of a Mac version? There is a Mac version of Qhull here:- http://www.math.sunysb.edu/~sorin/online-docs/qhull/qh-get.htm
                lapx
                Can this be achieved with this plugin.
                http://www.youtube.com/watch?v=Bw61WJbe2VU&feature=related
                Not working in my version.
                • V Offline
                  vklidu
                  I have the same question ๐Ÿ˜„
                    serraniadan
                    IT WAS SO DAMN SIMPLE!!! ๐Ÿ˜ excelent dude! Thanks ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    • DareDevilD Offline
                      DareDevil
                      Since a long time I dont use this plug, but I need it today and I reinstall it... and, of course, it dont works on my Win7 ๐Ÿ˜ž
                      I dont like to run as Administrator, so I searched an other "safer" way...
                      This is my solution for Windows :
                      • Move the qhull directory form the SU plugins directory to the root of ๐Ÿ˜„ (I dont like to put something in the root of C:, but I prefer to run as admin ๐Ÿ˜‰)
                      • In the SU plugin directory edit the qhull.rb and change
                      def self.initialize
                      	@qhull_path = Sketchup.find_support_file("Plugins/qhull")
                      	@qhull_path = @qhull_path + "/qhull-2003.1"
                      to
                      def self.initialize
                      	@qhull_path = "c;/qhull/qhull-2003.1"
                      ... and all works fine ! โ˜€
                      Edit 02/2015 :
                      This solution for windows is now obsolete since the plugin directory is in the User/AppData folder, no more authorization needed.
                        DareDevil
                        This plugin must be updated with Qhull 2012 for more stability on Win 64.
                        I did it for me, but I dont know if I can post it here... It's Avariant's plug, not mine ๐Ÿ˜‰
                          DareDevil
                          I'm not a Mac user for years...
                          There is a MacOS portage of Qhull. There is some one to port the Qhull plugin on MacOS with it ?
                          • 3 / 3
