    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Guidelines for adding a method to existing classes?
    12 Posts 8 Posters 503 Views 8 Watching
    • Chris FullmerC Offline
      WARNING from 2014: Extending the SketchUp classes is virtually always a bad idea and will make your plugin not be allowed onto the Extension Warehouse. Please find a different way to do things, other than by extending existing SketchUp classes, modules, methods, etc.
      I've written a bezier tool. I know there are lots of them already, but I needed to understand how it works for my script, and I wanted to make sure I had all the functionality I needed from it.
      So now I'm thinking about adding a .add_bezier method to Sketchup::Entities class. Is that ok to do? I know there is an offset.rb that adds an offset method to the Face class. But I didn't know if it is generally not ok to do? Or if it is acceptable? Should I consider a less obvious name for the method to reduce any possible conflicts from in case someone else does the same? My standard would be something like .clf_add_bezier
      Any thoughts? Thanks,
      Chris
      All my Plugins I've written
        coldsteel
        thanks for your works
          remus
          From my newbie standpoint i cant see a problem with it. If it doesnt exist already it's unlikely anyones going to be calling it mistakenly.
          I suppose the only problem would be if someone else decides to add the same method to the class in a later script.
          waits for people who know what theyre talking about
            well you're welcome. This however won't be a plugin in the traditional sense. It will be available for other script writers to incorporate into their scripts. But hopefully that is still helpful!
            Chris
              I'm not sure about this extending SU and Ruby classes.
              It's convenient, but I've avoided it so far as I'm worried that it might conflict. I've noted when I've been inspecting classes that with a few plugins installed there's quite a few additional methods, even to the private ones.
              I've just added it to a separate function, to be 100% sure.
              But I don't really know what I'm talking about, so I'll join you in the wait and see what people says.
                Yeah, that is my thinking too remus. I think I'll go ahead and name it with the initials in the front just to be safe.
                Chris
                waits along with Remus and Thom
                  Ohh, look at that tumbleweed! 😎
                  • JuantxoJ Offline
                    Juantxo
                    I would like to use a method like
                    3.1415.watts_to_kwatts
                    SketchUp warehouse does not let me to add the method to Float class:
                    class Float
                    def watts_to_kwatts()
                    Is there a solution to make sentence work storing method in a subclass?
                    • Dan RathbunD Offline
                      Dan Rathbun
                      You can try a subclass.. BUT it must be defined within YOUR or your company's) namespace.
                      Do not define it at the toplevel within Object !
                      class Juantxo;;Watts < Float
                        def to_kw
                          self / 1000.0
                      end # custom class
                      Your subclass should inherit a to_f method.
                      w = Juantxo::Watts.new(3.1415) kw = w.to_kw()
                      I'm not here much anymore.
                      • tt_suT Offline
                        tt_su
                        You can also use .extend() on single instances:
                        http://www.ruby-doc.org/core-1.8.6/Object.html#method-i-extend
                        Note that extending Entity instances would not be allowed by EW because the instances are global to everyone using the SketchUp environment. But for other types such as Point3d, Vector3d, String etc that would work.
                          class Sketchup;;Entities
                          	# Adds a clf_bezier_points method to the Entities class.  Arguments are the starting point of the bezier, first handle, the endpoint of the bezier, the endpoints handle.
                          	# All are either Point3d objects, or an array of [x,y,z] values.  The last argument is the number of segments the bezier should have.
                          	# This method returns an array of [x,y,z] points, starting with the given starting point and ending with the given endoing point.
                          	def clf_bezier_points( p0, p1, p3, p2, segs )
                          		point_array = []
                          		np = [0,0,0]
                          		cx = (3 * (p1[0] - p0[0]))
                          		bx = (3 * (p2[0] - p1[0])) - cx
                          		ax = (p3[0] - p0[0]) - cx - bx
                          		cy = (3 * (p1[1] - p0[1]))
                          		by = (3 * (p2[1] - p1[1])) - cy
                          		ay = (p3[1] - p0[1]) - cy - by
                          		cz = (3 * (p1[2] - p0[2]))
                          		bz = (3 * (p2[2] - p1[2])) - cz
                          		az = (p3[2] - p0[2]) - cz - bz
                          		(segs.to_i+1).times do |e|
                          			t = e/segs.to_f
                          			np[0] = (ax*(t**3)) + (bx*(t**2)) + (cx*t) + p0[0]
                          			np[1] = (ay*(t**3)) + (by*(t**2)) + (cy*t) + p0[1]
                          			np[2] = (az*(t**3)) + (bz*(t**2)) + (cz*t) + p0[2]
                          			point_array << np.clone
                          		point_array
                          	end # clf_bezier_points
                          	# Adds a clf_add_bezier method to the Entities class.  Arguments are the starting point of the bezier, first handle, the endpoint of the bezier, the endpoints handle.
                          	# This method returns an array that contains an arc object and an array of the edges, in order, in the bezier curve.
                          	def clf_add_bezier( p0, p1, p3, p2, segs )
                          		point_array = clf_bezier_points( p0, p1, p3, p2, segs )
                          		z = parent.active_entities.add_curve point_array
                          		bez_curve = z[0].curve
                          		[bez_curve,z]
                          	end # clf_add_bezier
                          end # Sketchup;;Entities class
                          This is the code I was planning on releasing as a developer's tool to add quick bezier curve ability.
                          Is writing it as its own .rb file that needs to be downloaded and installed really the best way? Or would it just made more sense to post is as standalone methods that would be easy for other scripter's to just copy and paste from here into their code?
                          And don't get me wrong, I fully expect that about 0 people will ever actually use this code. It was a bit of an exercise in figuring out how to extend SU's classes. But theoretically, what does everyone think the most efficient way to provide code bits like this is?
                          Chris
                          EDIT: Also, I was hoping that someone with some experience in these things could look over the code quickly and check if I have done anything majorly wrong that would quickly cause problems? Thanks in advance (Jim, Todd, Rick, TBD, TIG, Fredo, Tomasz, Whaat, the other Chris, and the other one, Wehby, and everyone that I missed, or didn't include who feels like they have answers! πŸ˜„ )
                          • danielbowringD Offline
                            danielbowring
                            Here delegators can be useful.
                            require 'delegate'
                            module DanielB
                              class SampleFace < DelegateClass(Sketchup;;Face)
                                def inner_loops
                                  return loops.find_all { |l| l != outer_loop }
                              def self.demo
                                face = Sketchup.active_model.selection.find { |e| e.is_a?(Sketchup;;Face) }
                                return if face.nil?
                                face = SampleFace.new(face)
                                puts face.inner_loops
