    Su slow to open
    12 Posts 6 Posters 1.1k Views 6 Watching
    • C
      caddict
      is it true that the more rubies su has to load, the slower it will be to open?
      i'm sure su used to open faster in the past...
      • S
        Sir
        i doubt it would make a noticable difference
        • thomthomT
          V-Ray for SketchUp add a significant delay to SU's statup time. I made a plugin which prevents VfSU from loading at startup and let it be loaded on demand.
          There is a possibility that extensions adds significant load time.
          • soloS
            solo
            SU2POV also increases the open time substantially.
            http://www.solos-art.com
            • C
              caddict
              that's interesting because i have SU2POV installed.
              thom, i like your idea of being able to load scripts as required. is your script specific to v-ray plugin or can it be generalised?
              • AdamBA
                AdamB
                I'm guessing that these plugins are registering onOpenModel() observers that are doing significant work - which isn't a brilliant engineering decision.
                Would be interesting to know what exactly they're doing.
                Adam
                • thomthomT
                  Adam
                  Not V-Ray. The lag is only during the initial load of the plugin, not during creating of new model.
                  It's really simple. It renames the v-ray loaded from VRayForSketchup.rb to VRayForSketchup.rb.disabled and then adds a menu item that will load VRayForSketchup.rb.disabled on demand.
                  • R
                    remus
                    Could you use the extensions window to disable plugins? (if theyre written to reside there, of course.)
                    • thomthomT
                      They won't be unloaded until next time you start SU though.
                      • R
                        remus
                        Good point, but as long as you turned it off each time you shouldnt have any problems.
                        • C
                          caddict
                          it's not really a very serious issue. i was just wondering how much i should restrain myself when it comes to new rubies πŸ˜„
                          • R
                            remus
                            You should be ok as long as you dont add all of them πŸ˜›
