    Catching Console errors upon crash
    6 Posts 3 Posters 468 Views 3 Watching
    • thomthomT
      I'm experiencing an bugsplat which I have a hard time tracking down.
      After I execute a specific action from my script, then go File->New to create a new scene, then once more File->New yet again SU bugsplats. I'm wondering about methods to debug that. I wonder if the Consoles outputs anything as it crashes which I won't be able to read before the window disappear.
      Anyone got ideas?
      • J
        Jim
        Not sure thomthom, but try starting Sketchup.exe with a batch file like this:
        sketchup.exe > log.txt 2>&1
        • thomthomT
          that does generate a log.txt file, but the output to that file seem to end quickly.
          • J
            Jim
            Maybe it's just buffering until something flushed it?
            • AdamBA
              AdamB
              These are very tough to track down.
              It sounds like stale data. Classic one is referencing duff data as SU tears down the parts hierarchy of a model. My general rule is never hang on to references; I know you've been digging deep into Observers recently.
              Adam
              [BTW What you building in there!]
              • thomthomT
                It's odd that it happens on the second File->New as in the first one, nothing is done.
                And yes, I do have quite a few observers and references. Though, I thought I was resetting everything onNewModel.
                I think I'll have to release a developers alpha, see if anyone can spot the culprit in my code.
                What I'm building is a plugin that allows cutout components to also cut through an opposite faced face. It does taht by creating a new invisible cutout. That's the simple stuff. The complicated stuff is making sure the extra cutout syncs with move,rotate,edits etc. That required allot more work than expected. Especially since I ran into so many bugs in the SU Ruby API requiring workaround upon workaround.
