    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Some new Renders..
    73 Posts 46 Posters 17.2k Views 46 Watching
      silver_shadow
      @chavinskee said:
      @silver_shadow said:
      here you go
      (www.box.net)
      12 panel each one is a A1 sheet.So the presentation was quite a huge board
      w ๐Ÿ˜ฎ w! superb images! how did you render the elevations in vfsu?
      you choose an elevation in sketchup, no perspective..set up the shadows and make sure you got the new vray installed and render it using the default camera ๐Ÿ˜‰
      • daleD Offline
        dale
        Always a pleasure to see your work. I use Vectorworks as well as Acad, but I prefer VW, but agree that it is users choice. Before SketchUp I used to do all my 3D stuff in VW. Way more complicated to do, but got pretty good final results.
        Anyway, Love your work.
        • 2 Offline
          21D
          Well i must say..i like vetorworks a bit more than autocad. But it comes down to user preferences.
          You can draw just a sfast as you can in autocad if you get to know it better and set up some basic shortcuts, and it also do have a 3d package in it, really bad, but overall i like it. worth while learning it.
          It has got layers, classes and saved sheets. Layers you can group all your pens which is switched on and off into layers and have them as groups switched on or off. It has got viewports also. Further on on the new vectorworks 2008 you have pens and fills you can make transparent, like if you want to make glass, draw in a class you set up called glass and give it transparency like su and it will show it like that in cad, anything behind it will still show depending on transparency.So id say its not a bad program to learn and also quite easy to learn it too. If you walk into a firm not knowing vworks, ill bet you you will be running the program by the end of the week, if no one really helps you.
          thnx for the advice mate, i will definitly try it out.
          "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
          Le Corbusier
          • K Offline
            kwistenbiebel
            Really great work there Silver! ๐Ÿ‘
            You have been busy.
            and yeah, vectorworks is more like drawing on a drawing board. it has a bit more of a graphical approach instead of the technical approach of Autocad, at least that is how I use it (I never touch the BIM module).
            On the other hand, it seems that both Vectorworks as Autocad will be obsolete...as Revit seems to be taking over drafting (and documenting) in arch firms nowadays.
              teofas
              ive always admire your modeling and render skills, i think this are great examples of the great things SU can do, very inspiring bro! ๐Ÿ‘
              http://www.spazioarquitectura.com
              • boofredlayB Offline
                boofredlay
                Wow, this is great work. I am taking notes...
                  mateo soletic
                  Amazing work Jacques. ๐Ÿ‘
                  Anything less from you and we would be disappointed.
                  And BTW thats a great board. ๐Ÿ‘
                  Concept Illustrations
                  • G Offline
                    goutham
                    mastery work......i am a beginner in v ray ..its a great inspiration..
                    thank you. ๐Ÿ‘
                      stereofidelic
                      wow ๐Ÿ‘
                      • utilerU Offline
                        utiler
                        @crazy eyes said:
                        Just a kinda unrelated question.
                        Are you self taught in SU and v-ray?
                        I want to improve my skill level and want to know how to go about doing that.
                        Cheers
                        I'm with crazy eyes..... ๐Ÿ˜ฒ
                        Just Curious...
                        • utilerU Offline
                          utiler
                          I am doing now su for 4 years and vray for about 2 years. Self taught. Me and Free agent used to work together and we helped each other to get into sketchup and vray. Sketchup is easy to learn and a lot of plugins helps you to do better models in quicker time. Thats what makes su so great. Vray is kind of a steep learning curve, but once you kinda know how to use it, you can use it in other platforms too. The interface is the same in other applications. So its a good thing to learn it. You can contact me if you need help, and ill help and support where i can. In modeling or in vray.
                          Gee that is a generous offer, Jacques. I might even do that..... ๐Ÿ˜„
                          Just Curious...
                          • utilerU Offline
                            utiler
                            By the way, georgous kid, Free Agent!!! reminds me of my little angel a few years ago... [yes, with the cow in the back ground as well!!!]
                            Just Curious...
                              sepo
                              Amazing stuff. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                              • F Offline
                                Fred
                                Hello, that's awesome
                                With what renderprogram did you rendered it?
                                Fred
                                • free agentF Offline
                                  free agent
                                  thank you, my little monster ๐Ÿ˜„... they grow up so quick ๐Ÿ˜ž
                                    steelers05
                                    silver, these are beautiful. U always blow me away with the scale of your projects and amount of details that go into them. Bravo, my friend. And my I apologize if this is a repeat question, by may I ask where you got those trees? Keep it up man, we all love seeing your work.
                                    • utilerU Offline
                                      utiler
                                      sure do. ๐Ÿ˜„
                                      Just Curious...
                                      • holmes1977H Offline
                                        holmes1977
                                        Such a FAN
                                        Exaggeration makes a dull story better.
                                        • cucsat2003C Offline
                                          cucsat2003
                                          http://i185.photobucket.com/albums/x165/hondsekont/06_1.jpg
                                          OMG!!!such a realistic pics with Su,can't belive it!
                                          Mr.Sylver Shadow,can you tell us how you make a roof with fur in the last pics?I really like it!
                                            silver_shadow
                                            the roof was build as a single plane, then used joint push pull to give it depth.
                                            Then i just dumped a projected texture over it, used these ones from this site
                                            http://www.cgtextures.com/texview.php?id=7528&PHPSESSID=8c15e745d9e197588c9c3888de8869cb
                                            and then for the edge i photoshopped it really quickly using a stamp tool with a round pointy brush for a brush stamp.
                                            That was pretty much that.
                                            Luckily it did not deform the texture too much when i did the projected texture.
                                            • 2 / 4
