    More controller boxes?
    6 Posts 4 Posters 885 Views 4 Watching
      BTM
      I've been making a model, and recently came to a point where I wanted to be able to change the accel in a joint, by having it controllable. Is it any harder to have things like accel, emitter lifetime, min/ max, max accel or any other things of the sorts controllable through code? Not really that necessary, I'm mostly just wondering if it requires a lot of coding, if it's just changing around a few lines of code a bit, or if it's even possible.
        MrPlanet
        I don't think so, you can only enter raw ruby into the boxes. nothing like 0.5-getVar("accel")
        I reject your reality and substitute my own.
          BTM
          ...I meant: would it be harder to make these boxes also include ruby code, maybe in SPIV, maybe sooner, maybe not.
          • P Offline
            phy
            From looking at the scrip it would possible, but I don't know enough of script to do it 😄 .
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
              CPhillips
              Its possible. But each field I make script controllable it dramatically adds to the complexity of the SP3 code. And it slows the simulation. Both of these issues will be fixed in SPIV.
              I think the best fix going forward is to set the joint parameters in an onTick (or whatever) event. So rather than having a formula in the accel field instead in onTick (or whatever) you can do something like this:
              joint.accel=righty*100.0
              joint.min=joint.min+10.0
              • P Offline
                phy
                Great that'll solve some of my problems.
