    Implementing Script Problem
    7 Posts 3 Posters 801 Views 3 Watching
      MrPlanet
      I need a script like
      if frame==350 then run script [1,5,3,9,2,3,1,0][(frame/50)%50];end;
      Anyone know the solution?
      I reject your reality and substitute my own.
      • P Offline
        phy
        if frame==349;[1,5,3,9,2,3,1,0][(frame/50)%8];end
        That should do it. frame==350 does not work for some reason.
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        • P Offline
          phy
          Hmm actually it doesn't work not sure why though it should.
          • P Offline
            phy
            there that works
            if frame>=350;[1,5,3,9,2,3,1,0][(frame/50)%8];end
              BTM
              I don't know exactly why it doesn't work, it's probably just trying to do the action ON the frame 350/ 349, but here's how to make it work:
              ... Put this in the joint controller field
              getVar("whats")*[1,5,3,9,2,3,1,0][(frame/50)%8]
              ... And this in any onTick box
              if frame==350 then setVar("whats",1);end;
              ...Oh, Phy got to it first 😆
              and his doesn't need an onTick field 👍
                MrPlanet
                THANKS A LOT!
                  MrPlanet
                  Thanks everyone, i used your help on this model
                  Error 404 (Not Found)!!1
                  (sketchup.google.com)
