    Changing Edge "endpoints" rendering option
    7 Posts 3 Posters 619 Views 3 Watching
    • R
      ruski_canuk
      So if Sketchup.active_model.rendering_options["ExtendLines"] lets me toggle the Window->Styles->Extension checkmark box, what is the secret password ( Sketchup.active_model.rendering_options["secret password"] ) for changing the 'Endpoints' checkmark in the same location? I've looked here http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html but to no avail.
      • Chris FullmerC
        Loos like it should be
        DrawLineEnds
        I haven't tested it, but it should work. In looking for it, I've found quite a few keys that are not listed in the API, and I've found at least one so far that is listed but not acutally supported. I'm in the process of writing this up for the API typos thread. Hope it helps,
        Chris
        PS: Running this in the web console will list all the possible keys:
        model = Sketchup.active_model renderingoptions = model.rendering_options renderingoptions.each { | key, value | puts key }
        All my Plugins I've written
        • Chris FullmerC
          Also, LineEndWidth should control the size of the endpoints.
          Chris
          • Al HartA
            Al Hart
            Chris, you might find these two functions interesting.
            One saves the value of the current rendering and shadow options, and the other traces out any changes.
            You run the first one, change something, and then run the second one.
            You need to replace trace() with printf() and add a \n line feed. I have a routine called trace which display the file name and line number of each output which makes it easier to see who is displaying the output)
            You can also see how you could add some other options to make this more complete.
            	def remember_options
            		rendering_options = model.rendering_options
            		$rps_old_rendering_options = {}
            		rendering_options.each_pair do |name , value|
            			$rps_old_rendering_options[name] = value
            		end#loop
            		shadow_info = model.shadow_info
            		$rps_old_shadow_info = {}
            		shadow_info.each_pair do |name , value|
            			$rps_old_shadow_info[name] = value
            		end#loop
            	end#def
            	def compare_options
            			old_value = $rps_old_rendering_options[name]
            			next if value == old_value
            			next if value.kind_of?(Sketchup;;Color) && value.to_s == old_value.to_s
            			trace("rendering_options[\"%s\"]=%s old; %s", name, value, old_value)
            			$value = value
            			$rps_old_value = old_value
            		end#loop
            			old_value = $rps_old_shadow_info[name]
            			trace("shadow_info[\"%s\"]=%s old; %s", name, value, old_value)
            			$value = value
            		end#loop
            	end#def
            Al Hart
            http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
            IRender nXt from Render Plus
            • Chris FullmerC
              Hey, that's pretty cool Al, thanks! I'll keep those two methods handy.
              Chris
              • R
                ruski_canuk
                Chris -
                The answer to my question and then some. Thanks Chris!
                So how did you discover this undocumented mystery?
                • Chris FullmerC
                  I used the code they posted in the API in RenderingOptions "each" method here:
                  http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#each_key
                  But the example puts each key into a messagebox, so I changed "UI.messagebox" to "puts" so it would send it to the Ruby Console. The code looks like this:
                  renderingoptions.each_key { | key |   puts key }
                  and I run it in Jim's Web Concolse, which is my favorite Ruby development tool.
                  Then I just went through the returned keys one by one and compared then to the API. There were quite a few missing ones in the API, and some in the API that don't actually exist.
                  Chris
