    Gearshifting with Variables?
    4 Posts 3 Posters 634 Views 3 Watching
    • K Offline
      klaufi
      i want to shift between gears using variables, for example pressing A for driving in first gear, S for second and so on. Would it work if I let the keys change a variable, for example setVar('acc',0.0);if Key('a')==1 setVar('acc',10.0) else if Key('S')==1 setVar('acc',20.0);end;
      (there are lots of mistakes in the syntax, could anyone help?)
      Also, is it possible to set a variable into a normal window like if you have a motorand write Accel: getVar('acc') ?
      • W Offline
        Wacov
        Setting a variable with a key for each setting is easy.
        if key("a")==1; setVar("gear",1); end
        if key("s")==1; setVar("gear",2); end
        if key("d")==1; setVar("gear",3); end
        if key("f")==1; setVar("gear",4); end
        Should do it. You can't get variables in a white field, but a motor's controller will accept values over 1, so you can increase the speed by multiplying your normal controller by 1.something.
          BTM
          hmmm... Wacov is right, sorta. That would be if the gears were all seperate though. Better way:
          if key("a")>=0.5 then setVar("gear",0.0);elsif key("s")>=0.5 then setVar("gear",10.0);elsif key("d")>=0.5 then setVar("gear",20.0);end;
          for the motor, type getVar("gear").
          that MIGHT work.
          • K Offline
            klaufi
            thanks but meanwhile i've found out in SP-wiki^^
            my code so far:
            if frame==1;setVar("acc",0.5);end;
            if key("a")==1;setVar("acc",0.6);
            elsif key("s")==1;setVar("acc",0.7);
            elsif key("d")==1;setVar("acc",0.8);
            elsif key("f")==1;setVar("acc",0.9);
            elsif key("g")==1;setVar("acc",1);
            elsif key("r")==1;setVar("acc",0.4);
            elsif key("e")==1;setVar("acc",0.5);end;
            getVar("acc")-0.5
            with a,s,d,f,g for gears, e for empty and r for reverse
