    Transformation.axes problem
    8 Posts 2 Posters 684 Views 2 Watching
      trottolino
      Hello everyone.
      I need to display the drawving direction of all the edges of one or more curves in my draw.
      The observer must be able to check for any edge of the selected curves which is the first and the end point.
      I thought to do this by placing at the center of each edge a 3D arrow component oriented from first point to end point.
      This is the code of my script:
      @mycomponent is my 3D arrow component
      @mymodel.selection.each {|e|
      if( e.typename == "Edge" )
      @myedgeID = e.entityID
      @p1 = e.start.position
      @p2 = e.end.position
      @p0 = Geom::Point3d.linear_combination 0.5, @p1, 0.5, @p2
      @my_vector3d = @p1.vector_to (@p2)
      t = Geom::Transformation.axes @p0, @my_vector3d, @my_vector3d, @my_vector3d
      @my_comp_instance = @mymodel.active_entities.add_instance @mycomponent, t
      The problem is that all the arrow components are correctly created in the right direction, but it's size is null and
      almost invisible!
      What's wrong?
      • Chris FullmerC Offline
        The axes all need to be different from eachother. Setting them all the same will squash your component like your seeing right now. So you need to figure out how to define the other 2 axes. I've got some thoughts on how to do it, but it all depends on what the geometry involved is. Is it just a simple arc that all lies on a single plane? OR is it always flat on the x,y plane? Got a picture of it?
        Chris
        All my Plugins I've written
          Oh yeah, and the possibly easier way is with Transformation.new (point, zaxis).
          So your transformation would be:
          t = Geom::Transformation.new(@p0, @my_vector3d)
          That will insert you component with its origin onto the centerpoint of your edge. And it will rotate it so that its up axis is oriented with the line vector. I think that is a better transformation to use in this case.
          Chris
          EDIT: Yup I tested it with your code and it works well. Just replace your current transformation with the one I wrote and that should do the trick. Well, that assumes that your arrow component is built pointing upwards, because this will orient its blue axis to the line.
            trottolino
            Great, this works perfectly!
            Think that this method was under my eyes but I've never tried it.
            Thank you very much.
            And if I want to insert my component with a different scale, how do I combine multiple transformations?
              I would insert it using the method above. Then I would create another transformation for the scale. Just a simple uniform scale:
              t = Geom::Transformation.scaling scale
              That should do the trick. Apply it to the component with
              @my_comp_instance.transform! t
              I'd be interested if anyone had a simple way to combine the two transformations before applying them separately though. I've little to no luck with that. I always do it in steps.
              Chris
                trottolino
                But this second transformation moves component from its origin @p0
                Did you notice?
                  Sorry, try it with this version of transformation:
                  t = Geom;;Transformation.scaling point, scale
                  Yours would look like:
                  t = Geom::Transformation.scaling @p0 scale
                  Does that solve it?
                  Chris
                    trottolino
                    Of course.
                    In the meantime I also found the right solution.
                    This Sketchup is very powerful when you found the correct sequence of commands script!
                    Thanks again.
                    I think for my project (some ambitious) I will still need your advice.
                    I hope that you are always online these days as then.
                    Bye
