    How to remove common edges???
    6 Posts 3 Posters 546 Views 3 Watching
      davidsuke
      I have one face with an offset, then i draw another face in the middel on this and i want to delete two edge likee this.
      http://img230.imageshack.us/img230/2740/dibujocut.png
      http://img114.imageshack.us/img114/378/dibujo1c.png
      How can i do that???
      • Chris FullmerC Offline
        You can find the edges that your new face does not have in common with the faces on its sides. Have you got those 2 faces sorted somehow?
        All my Plugins I've written
          Also, since you must know those endpoints, you could then serach through the edges and find the 2 edges that have the correct endpoints and delete those edges.
          • honoluludesktopH Offline
            honoluludesktop
            Hi, If you open the Model Info statistics window when you draw, you will see that you have 14 edges and 3 faces. If you remove (select line by right mouse click, erase) the 2 edges indicated, you will have 12 edges and three faces. Is that what you wanted?
              I think so, but this is the ruby forum, so I think he wanted a ruby solution πŸ˜„
              Chris
              PS - you should get into Ruby Honolulu, I know your a programmer at heart
                honoluludesktop
                Oops, came here from "new posts". Got to read those subject titles better. I took a couple of swings at ruby, then put the bat back on the rack before my hands blistered πŸ™‚
