    Coding Field
    9 Posts 4 Posters 1.1k Views 4 Watching
    • P Offline
      Physicsguy1
      Can there be another field that won't have to function on a certain event? i ran into this when i was building an arm, which had a receiver that calculated and processed everything, but the ontouch and ontick fields require an event to trigger them. Can there be a simple field for code like: if getVar('sens')==1 then setVar('claw',0.6);end
      if a==1 then setVar('claw',0);end?
        BTM
        ...ontick does it fine, but there can't be 2 ends, one should be elsif.
        • W Offline
          Wacov
          Actually there can be as many ends as you want. But in this case, there could be a conflict, so you may as well use elsif. Also, onTick works fine and doesn't need an event to trigger it; it's a 'frame' event, occuring every frame or every rate frame. Next version there should be global script, which'd be perfect for this.
            MrPlanet
            if getVar('sens')==1 then setVar('claw',0.6);elseif joybutton("a")==1 then setVar("claw",0);end;
            I reject your reality and substitute my own.
              MrPlanet
              I think thats it...
              • W Offline
                Wacov
                You don't need the first 'then'... but yeah
                  BTM
                  the second time you use setVar("claw"), should be getSetVar.
                  • W Offline
                    Wacov
                    If it's going in onTick, what's the point?
                      BTM
                      yeah, you're right πŸ˜†
