    Set_attribute and undo operations
    5 Posts 4 Posters 630 Views 4 Watching
      Jim
      I'm using attribute dictionaries to manage entities in a tool, but whenever I call set_attribute, another operation is pushed on the undo stack creating unnecessary (in my opinion) undo operations. The operations show up as "Undo Properties" on the Undo button Tooltip.
      Is it possible to make SU not put these changes on the undo stack?
      • AdamBA Offline
        AdamB
        Can you not just keep a reference to the dictionary and twiddle key-value pairs without calling set_attribute?
        • scottliningerS Offline
          scottlininger
          Jim,
          Consider trying something like this, which will group them into a single undo event...
          Sketchup.active_model.start_operation "Modify Attributes"
          # make multiple attribute changes here.
          Sketchup.active_model.commit_operation
          ...and if you're responding to an observer event, you might consider something like this, which will "append" your attribute changes to the previous event. See start_operation for details on the 3rd param...
          Smodel.start_operation "Modify Attributes", true, false, true
          Hope that helps!
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
            Third param?? Where did that fly in from?
              ...correction four... ...now that might come in handy.
