!Help Please
why is this happening ?
There may be some incompatible scripts in your plugins folder.
You may need to update an auxiliary or prerequisite ruby, such as progressbar, or something like that.
I know that EventRelay gave me some trouble with other plugins. After I removed that, a similar error message went away.**I see that Autocenterpoint occurs twice in your Plugins drop down menu. One is at the top and the other is the one with the flyout in your illustration.
Do you have two instances running with different version numbers? one way to correct this is to delete them both from the plugin folder and download the plugin again, if that is possible. Or determine which is the problem and delete that one. Restart SU to verify if the error message is gone.This also appears to be a problem with Organizer.rb .
I see the first instance of Autocenterpoint is actually spelled as two separate words and the second instance is one word in the menu display. What's that about?
These are just my observations. Anyone else care to respond? -
Organizer is just trying to load the .rb files it finds in the subfolders of your Plugins menu.
The usual fix is to explicitly exclude subfolders that are created by other plugins. You can do this by adding the subfolder's name to the "SmustardOrganizerExcludeFolders.txt" file. If that doesn't fix it, contact me at Smustard and we'll troubleshoot it.
Register LoginAdvertisement
