    Vray animation
    17 Posts 6 Posters 1.7k Views 6 Watching
      alpro
      Unfortunately I've had some extra time on my hands, so I decided to try to really sink my teeth into Vray. Have been playing with it for awhile but haven't tried to seriously use it till recently. I'm looking for some C&C, especially from the Vray users. Don't know why but it seems to take a bit before it loads. [flash=720,480:1ilbeny7]http://vimeo.com/moogaloop.swf?clip_id=4105243[/flash:1ilbeny7]
      • F Offline
        FoXar
        I'm really looking forward to see your animation, unfortunately it doesn't load..
        It's just a white rectangle, is it me or do others experience the same problem?
        Grats..
        FoXy..
          teofas
          yep, me too,,,,i cant see it 😐
          http://www.spazioarquitectura.com
            alpro
            Yes, I can't seem to figure out how to embed it. Got it figured out, but its alot crisper before I uploaded it to Vimeo, is there any way to not have the quality degrade so much?
            • EarthMoverE Offline
              EarthMover
              It played for me. Nice work. I'm particularly fond of the texture for the pool deck. πŸ˜‰
              Content Creator at Skapeup
              • soloS Offline
                solo
                Very cool!!
                How long did it take to render and on what machine?
                http://www.solos-art.com
                • F Offline
                  FoXar
                  Okay, now I see it, looks very good, nice use of solo's garden pack.
                  But maybe you could try to brighten up the sky a bit, but still looks good ;]
                  Grats..
                  FoXy..
                    alpro
                    This is a 20Mb model, don't know if thats large but 3/4 of the interior is modeled also including casing, base, kitchen, bathrooms, some lighting and furniture, plus it has a ton of Solos plants, and some large textures like the grass. I used every trick I know, using components, making whole components from 1/4s and 1/2s, deleting unneeded lines and faces, purging, using layers, hiding parts that couldn't be seen in the render areas. The model was quite manageable, the problem I ran into was the amount of time it took Vray to process all the information, even had a few memory allocation crashes. I had 15 scences which I had to break down into 3 scene segments. Afterall with setting up the scenes, some crashes, some experimenting, it took about 40hrs to render on an AMD 2.6 dual core processer with 4gigs of ram. Also had displacement on the stone work, so I imagine that uped the size a little.
                    Mike
                    • H Offline
                      HFM
                      where did you get the water texture?
                      I'm still searching for a good one to use in my project πŸ˜„
                        alpro
                        Thats actually a vismat that I played with a little, no texture at all, just diffuse colors, reflection layers,refraction layer, and a procedural bump. I can upload it for you if you want.
                        Mike
                        • H Offline
                          HFM
                          That would help me very much πŸ˜„
                            alpro
                            Here you go
                            Pool water.zip
                            • H Offline
                              HFM
                              It gives an 'Invalid ASGvis material file' if I try to load it in my model?
                                alpro
                                Not sure why, all I did was export it out of my model and then zip it, is there another way? What version of Vray are you using?
                                Mike
                                • soloS Offline
                                  solo
                                  I've never saved an vismat but I have noticed there is a 'pack' and export option.
                                  I assume the pack button maps the diffuse and bumps together as well as the multiplier and reflection values and saves them together.
                                    alpro
                                    Try this one, as per solos suggestion, I packed this one instead of exporting, it automatically zipped it so now I'm wondering what the export feature is exactly used for.
                                    Mike
                                    Pool water.zip
                                    • H Offline
                                      HFM
                                      I'm getting the same error when I try to import it πŸ˜• I'm using Vray 1.5 [?] with SU 6
