    Vray animation
    17 Posts 6 Posters 1.7k Views 6 Watching
    • F
      FoXar
      I'm really looking forward to see your animation, unfortunately it doesn't load..
      It's just a white rectangle, is it me or do others experience the same problem?
      Grats..
      FoXy..
      • T
        teofas
        yep, me too,,,,i cant see it 😐
        http://www.spazioarquitectura.com
          alpro
          Yes, I can't seem to figure out how to embed it. Got it figured out, but its alot crisper before I uploaded it to Vimeo, is there any way to not have the quality degrade so much?
          • EarthMoverE
            EarthMover
            It played for me. Nice work. I'm particularly fond of the texture for the pool deck. πŸ˜‰
            Content Creator at Skapeup
            • soloS
              Very cool!!
              How long did it take to render and on what machine?
              • F
                FoXar
                Okay, now I see it, looks very good, nice use of solo's garden pack.
                But maybe you could try to brighten up the sky a bit, but still looks good ;]
                Grats..
                FoXy..
                  alpro
                  This is a 20Mb model, don't know if thats large but 3/4 of the interior is modeled also including casing, base, kitchen, bathrooms, some lighting and furniture, plus it has a ton of Solos plants, and some large textures like the grass. I used every trick I know, using components, making whole components from 1/4s and 1/2s, deleting unneeded lines and faces, purging, using layers, hiding parts that couldn't be seen in the render areas. The model was quite manageable, the problem I ran into was the amount of time it took Vray to process all the information, even had a few memory allocation crashes. I had 15 scences which I had to break down into 3 scene segments. Afterall with setting up the scenes, some crashes, some experimenting, it took about 40hrs to render on an AMD 2.6 dual core processer with 4gigs of ram. Also had displacement on the stone work, so I imagine that uped the size a little.
                  Mike
                  • H
                    HFM
                    where did you get the water texture?
                    I'm still searching for a good one to use in my project πŸ˜„
                      alpro
                      Thats actually a vismat that I played with a little, no texture at all, just diffuse colors, reflection layers,refraction layer, and a procedural bump. I can upload it for you if you want.
                      Mike
                      • H
                        HFM
                        That would help me very much πŸ˜„
                          alpro
                          Here you go
                          Pool water.zip
                          • H
                            HFM
                            It gives an 'Invalid ASGvis material file' if I try to load it in my model?
                              alpro
                              Not sure why, all I did was export it out of my model and then zip it, is there another way? What version of Vray are you using?
                              Mike
                              • soloS
                                I've never saved an vismat but I have noticed there is a 'pack' and export option.
                                I assume the pack button maps the diffuse and bumps together as well as the multiplier and reflection values and saves them together.
                                  alpro
                                  Try this one, as per solos suggestion, I packed this one instead of exporting, it automatically zipped it so now I'm wondering what the export feature is exactly used for.
                                  Mike
                                  Pool water.zip
                                  • H
                                    HFM
                                    I'm getting the same error when I try to import it πŸ˜• I'm using Vray 1.5 [?] with SU 6
