    Formula and User Interface
    5 Posts 3 Posters 876 Views 3 Watching
    • MALAISEM Offline
      MALAISE
      Hi All,
      I'm studying the way to use formula inside UI. How to write formula which length exceeds the field ?Controller.png
      MALAISE 😄
        BTM
        The box is small, but you can write as much as you want. it just won't all be visible at once. Except for in SP3X, where the boxes appear around half as wide as the UI window, which makes it even easier.
          Maybe you can write any thing you want in the Notes Block then make a Copy Past. 😉
          • MALAISEM Offline
            MALAISE
            Thanks Friends, for thoses hints.
            @ Pilou, I was led to such a solution 😉
            MALAISE
            • MALAISEM Offline
              MALAISE
              MALAISE
