    Quick Irender Nxt Hospital Render
    6 Posts 4 Posters 714 Views 4 Watching
      derryatlanta
      Not enough Nxt on here!
      10 mins render of a project, existing massing small tweaks to default outdoor settings in Nxt with some material edits.
      2 mins in PhotoShop to achieve "tilt shift" effect. Thanks for looking.
      Cheers,
      Nigel
      Stop your grinnin' and drop your linen
        cadmunkey
        I like it, cute model!
        • soloS Offline
          solo
          "Tilt shift'?., I believe I've heard of this before but cannot recall, care to elaborate?
          I agree cute looking render, looks like a toy model.
          http://www.solos-art.com
            cadmunkey
            Solo, that is the point of the tilt shift method, to create that toytown feel. There are plenty of tutorials on it out on the web, but this place enables you to take you photos and tilt shift them for free http://tiltshiftmaker.com/
              derryatlanta
              Thanks for the comments!
              Good link, Cadmunkey. I'm a fan of this miniaturization melarkey.
              Seems to me that birdseye aerial shots with built up areas and lots of trees work really well for this effect, if anyone wants to give it a try.
              Cheers,
              Nigel
                Roger
                "Shift and tilt" actually comes from the world of view camera photography. Lets say you photograph a building with the base of the camera parallel to the ground. You don't want to tilt the camera up because that might cause the verticals to diverge. With a view camera, you can move the lens up while the film of sensor stays where it is. This allows you to get the top of the building into the scene while keeping the verticals parallel. You can also tilt the front lens board of the camera. When you tilt the lens you also tilt the plane of focus. Imagine photographing a brick driveway leading up to a house. Your client is the brick maker and you want all of the bricks to be sharp right from the front of the camera to way off in the distance. To do this, you tilt the lens in the direction of the bricks.
                The irony is that this technique was originally used to make things sharper. Recently it has become fashionable to either use a large camera to simulate a small simple camera or to isolate the area of greatest interest by throwing extraneous elements out of focus. To do this you just tilt the lens back until only a few bricks in the driveway are in focus.
                The tilt is also know as the Schiemphlug (SP?) effect after its inventor.
                In essence, blurry has become the new sharp.
                http://www.azcreative.com
