    Simple bench
    10 Posts 5 Posters 2.1k Views 5 Watching
    • W Offline
      watkins
      Dear All,
      A simple bench modelled on a image seen in a woodworking magazine. The image only showed the top section of one of the supports, and so the interpretation and the dimensions are my own.
      Regards,
      Bob
      Bench_V6.skp
        Very interesting, Bob. It looks like the legs could be turned to make a low bench, too.
        • W Offline
          watkins
          Dear David,
          I think the supports would work both ways, but the way shown is probably more stable. The 'horns' of the supports could probably be shorter as they take up too much seating space. The arrangement makes a nice garden bench in that can be disassembled and stored when not needed. The same idea might be used for a simple table. I would probably use three supports (milking stool principle), with a triangular table top and three benches. The supports for the table could probably arch outward from the centre providing more leg room. Anyone for a picnic?
          Regards,
          Bob
            Dear Bob,
            A triangular picnic table along the lines of that bench would be pretty neat. I look forward to seeing it.
            Dave
            • W Offline
              watkins
              Dear David,
              A quick design study. Must go to bed (00:18).
              Table and benches_V6.skp
                Dear Bob,
                That's neat. excellent work, sir.
                I think you need to set up a woodworking shop. A shed in the back garden could work.
                  Jim
                  Heh, I thought it was a table and Bob was showing off the underside.
                  • W Offline
                    watkins
                    Dear David,
                    I have always wanted to work with wood, but my career path has left me with very little free time. Also, I live in the smallest of houses with a small garden, and so no room for a workshop. Perhaps one day.
                    I like the idea of using the weight of the table to lock the supports into position. I think the table-top could be split into two, dividing one of the square corner profiles. Some method of joining and stiffening the other end would be needed, but splitting the table in this way would make storage much easier.
                    Dear Jim,
                    Your view of the world is always interesting. I think it is called lateral thinking.
                    Regards to both,
                    Bob
                      Exactly... 😲
                      • boofredlayB Offline
                        boofredlay
                        I thought it was upside down too. πŸ˜†
