    Help with Ignored components...
    4 Posts 3 Posters 775 Views 3 Watching
    • K Offline
      Kus
      Hi!
      It is my first time I have worked with this plugin and I have a problem. Some pieces, that I have ignored, go through the floor on the end of the animation. Can I do anything to prevent this??
      Here is the video of the animation:
        BTM
        ...They can not be set to ignore, or they will ignore everything. You're best bet is o make them boxes, not ignored, than to add a breakable joint with low strength to the middle part, and attach the pieces to it, so they don't break before they hit the ground.
          CPhillips
          I couldnt see the problem in the video. But ignore does mean the object has no collision. BTM's solution sounds like it would work.
          • K Offline
            Kus
            Well I did not succeed... I attached the model for you geniuses. I would be very happy if anyone would give it a try πŸ˜„
            rubik_crash010.skp.zip
