    Billboard 3D trees, results.
    13 Posts 7 Posters 4.6k Views 7 Watching
    • RichardR Offline
      Richard
      Hmmm?
      I tried something different with trees to test what possibilities might exist to improve the rendered output from billboard trees!
      1. Exported Onyx tree model
      2. Imported to Maxwell, applied bark an leaf maps,
      3. Rendered high res, low render time, sky dome,
      4. Exported rendered image, alpha map, depth map (z buffer)
      5. Created MXM (maxwell material) colour map, clip map, depth map as displacement,
      6. Created SU billboard with tree mapped and linked to MXM
      7. Exported render.
      Here is the result, it actually created I think far better depth than just flats.
      The nice thing is the shadow cast on areas of the tree itself and thus the correct response to sun direction as opposed to normal billboards. And best of all low cost in sketchup.
      http://img6.imageshack.us/img6/8133/12562617.jpg
      BUILTBRAND.COM.AU
        remus
        The end result is certainly very good, i think youd be hard pushed to tell it was a billboard in a render.
        • RichardR Offline
          Richard
          God I've got to fix the colour and brightness of my laptop - thats dark!
          BUILTBRAND.COM.AU
          • P Offline
            Phil Rader AIA
            Can you expand on your item #6. IE which program is linking to the MXM file. Is SU linking to and MXM file?
            http://www.philrader.com
            • RichardR Offline
              Richard
              Yes phil, I just used the clip map B/W as the map in SU and then linked the SU material to the MXM. The MXM is pretty simple just colour, clip and displacement maps!
              BUILTBRAND.COM.AU
                diegog321
                Hi Richard
                Im very impressed with your work. Is too bad that we have to find ways to bypass skecthup inability to work with more than a few thousand polygons. Even on the most powerful computers.
                Can you share your mxm file and component, so other can test it as well and perhaps build a collection in the future.
                Have you tried rendering these trees in top view? Do they look real πŸ˜† ?
                In any case they are an excellent work
                congratulations
                • RichardR Offline
                  Richard
                  Thanks mate! Unfortunately I cant share the models or images in the MXM's due to Onyx licensing!
                  BUILTBRAND.COM.AU
                    dtrarch
                    Richard
                    Good tree but no shadows on trunk.
                    I have the same deal using ATL 3d trees for flats.
                    Question is the detail in trunk and branches more important than shadows.
                    In ATL one can do it either way.
                    Opinion please.
                    ATL tree attached.
                    dtr
                    • broomstickB Offline
                      broomstick
                      dtrarch, that's what I was going to say too: although I don't like particularly the atl trees. Using onyx the result is much better IMO. πŸ˜„
                      Nice job Gaieus!
                      This metod also works for 2D props in photoshop πŸ˜‰
                      • RichardR Offline
                        Richard
                        @dtrarch said:
                        Richard
                        Mate I used some low transparency on the leaves (pre V2 to get some softer leaves) shadows went unfortunately. I was testing a few things at the same time!
                        With maxwell use of 3d trees comes at little cost, once any 3d highpoly asset is used you are forced into the studio app anyway given SU's polylimits!
                        Onyx trees are the bomb! And completely customizable!
                        BUILTBRAND.COM.AU
                          diegog321
                          I thought so...
                          When I get a little time im going to make some from freeware trees, Perhaps we can compare them with onyx but is going to take more time to them.
                          Hope to see you improve πŸ˜„
                          what will if you if you render the tree in perspective like an isometry. It gets me curious.
                          • honoluludesktopH Offline
                            honoluludesktop
                            Richard, "low transparency to soften", nice tip for a beginner like me to explore. Is that why some of the bunches of leaves in the center of a cluster look diffuse? Maybe that's the way it looks when the edge between the leaves and sky is well integrated. This got me to thinking that for the sake of the perspective, perhaps the reverse is better. Diffuse at the more distant edges, and sharper on the surfaces closest to the observer. Have you tried it that way?
                            I could cutup the tree into sections that can be blurred, or made a little transparent to achieve the desired effect. Best perhaps for mid-range 2d veggies? BTW, do I misunderstand this post? What is a 3d billboard tree, as vs a 2d tree?
                            • RichardR Offline
                              Richard
                              Sorry mate, I thought I had replied earlier!
                              I didn't play any further than this test given the results of billboards (yes same as 2d, just a commonly used term for same!) in rendering just has trouble compeating with 3d so I dropped the tests, though I did some later tests just using the map on a sandbox tooled single mesh and bought forward and back the obvious parts of the plant, I do this with a few plants I use to get better sun shadow response and it worked ok on the tree too. Cant find the tests now!
                              BUILTBRAND.COM.AU
