    Could someone help tutor me on the codes?
    5 Posts 5 Posters 965 Views 5 Watching
    • P
      Platypus5
      I need help understanding the codes used in the current models. I don't understand at all what [0,1,0] means, for example. Could someone help tutor me?
      • C
        CPhillips
        Some fields can accept a "vector". A vector is a direction in x,y,z coordinates. X is left/right. Y is front/back and Z is up/down.
        [x,y,z]
        So if I want to have an object emitter go "left" instead of straight up (as it does by default) you could put this formula in:
        [10,0,0]
        The body will emit from the side with a strength of 10.
        [10,0,10]
        The body will emit from the up and to the side.
        [0,0,-10]
        Straight down.
        Try:
        [rand(20),rand(20),0]
        By default the emitter strength is effectively [0,0,strength]. Remember the last number is Z and that is straight up.
        • T
          Trimmer
          Thank you CPhillips,
          I too am watching these post in hopes of learning more. Its great to see a guy of your knowledge taking the time to help others learn.
          Thank You!!
          • M
            MrPlanet
            THANK YOU!!! β˜€
            I reject your reality and substitute my own.
            • V
              Verrou
              Thanks for these πŸ˜„
