    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    First class
    17 Posts 12 Posters 1.3k Views 12 Watching
    • soloS Offline
      solo
      My First Vray interior, dabbled a little with exteriors and seeing that my trial ends soon I decided to try an interior.
      Had a few issues with textures that took some searching to overcome, I am pleased with the results especially the speed.
      The model is part of a larger project that is on hold at moment (for the last year) so I decided to throw in a few components and try out Vray interiors.
      Vray has proven to be an awesome tool and I will recommend it to anyone wanting a quality rendering solution, I have it on my wishlist for when things get better.
      http://img140.imageshack.us/img140/7236/rotunda1000.jpg
      http://www.solos-art.com
      • david57D Offline
        david57
        Its Ok, Solo, dont be ashamed to be using the free version, ive been using the
        free version of sketchup.
          tgb57781
          Good job!
          V-RAY is a awesome render engine exactly.
          But I am a beginner 😳
          But, in the chart pillar does not have the heavy feeling of quantity probably.
          And the the reflection is insufficient.
          Thanks for the share.
          Richen 😉 Chinese
          • E Offline
            Ecuadorian
            True fuzzy reflections! 👍
            -Miguel Lescano
            • boofredlayB Offline
              boofredlay
              Very nice Pete but I think you need to add a couple of drunks waiting for their flight 😄
              Great work.
              • soloS Offline
                solo
                Thanks guys.
                I had some more playtime so decided to do a few changes like those mentioned above and a few light fixes and texture changes.
                http://img518.imageshack.us/img518/8108/airportlounge1000.jpg
                  boofredlay
                  Nice 👍
                    steelers05
                    Very good start solo... looks like youve been using vray for a while. My only critique is actually something you could work with in PS...the image just seems a little muted-maybe a little more saturation/contrast. But good work.
                      dylan
                      Love it Pete.
                      The background behind the glazing makes a real difference.
                      Excellent work.
                      http://dmdarchitecture.co.uk/
                      • E Offline
                        edmund
                        ...I am pleased with the results especially the speed.
                        How fast are we talking...
                        I'm a big Podium user and as you know it has some quirks, but it's speed seems to be unmatched.
                        BTW those renders look fantastic.
                        • soloS Offline
                          solo
                          Thanks guys.
                          Steelers, I must say that once you get a basic understanding using Vray it all falls into place, there is a lot to learn but that can be done on a need to need way once you have the basics.
                          There are some quirks that one needs to overcome like some glass materials that block sunlight, vismat selections without previews (only texture updates which can be a slow process when selecting textures) or ways to adjust textures as they do not represent themselves in the SU materials for edit.
                          The image does look muted on my laptop, but on my main modeling rig it looks pretty vivid, I may need to calibrate my monitors again.
                          Dylan, yes once I changed my glass material to allow in the sun I was also able to export a .png with alpha support thus added the background which worked great.
                          Edmund, Podium is an awesome and fast tool, still one of my daily tools, and with TBD working on blurred reflections at moment I do not see why the above image will not be possible with Podium soon. As for the speed of the above, I rendered at 1900 x 900 using a modified render setting which on a quad took around 17 minutes, very good IMO.
                          • marked001M Offline
                            marked001
                            that background totally sells it now 👍 definitley what was missing.
                            http://www.revision21vis.com
                            instagram: revi21on
                              dlomas
                              Fantastic render...Marble Tiles on the floor + Marble Posts would have high class effect. I'd cut down the gloss/specularity on the posts a bit, med to high sheen.
                                ScottPara
                                Great work Pete. I agree the background makes this look great. Nice use of materials but the columns are lacking something.
                                Scott
                                Love the fact that some HATE my avatar.....
                                • soloS Offline
                                  solo
                                  Still playing around, I wanted to try a few textures and lights but most of all to pose my sofa, as the next model pack is a no go.
                                  http://img17.imageshack.us/img17/8218/vrayroom1000.jpg
                                    boofredlay
                                    http://icons.iconator.com/438/ICONATOR_20d4f78084d5f0d927c2287f88bff773.gif
                                    • MALAISEM Offline
                                      MALAISE
                                      Hi Solo,
                                      It's always a pleasure to look at your renders. Airport background enlights the Hall. Looking at the third picture, I notice the big plant is not really mirrored on the tiles, we see the pot but not the plant's foot.
                                      I hope it's may help. 👍 👍
                                      MALAISE
