    Internet Explorer 8 & SketchUp
    4 Posts 4 Posters 567 Views 4 Watching
    • J
      Jim
      Microsoft has released IE 8. I assume SketchUp will use version 8 for WebDialogs, if installed? Has anyone tried it?
      • thomthomT
        I use Windows7 which has IE8 installed. Not the final release though. But it's working fine.
        • D
          dtrarch
          Jim
          I have IE8 installed and no problems (yet)
          Win XP Pro
          Note that iespell is found in the rt click menu but no icon shown.
          dtr
          • scottliningerS
            scottlininger
            The only problem we've seen so far (that I'm aware of), is that a couple of folks have required a restart if they install IE8 while SketchUp is open.
            So first suggestion is to install IE8 with all apps closed. But if you do see a webDialog problem, a system restart should fix it.
            Cheers,
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
