    Trigger
    4 Posts 3 Posters 552 Views 3 Watching
    • P Offline
      Physicsguy1
      Is it possible to trigger something when a certain speed is achieved? I would like it if you could create a wing that has lift that depends on the speed. I am tired of seeing a plane liftoff before it rolls five feet on the run way. I want the lift to gradually increase in relation with the speed of the wing. Could you have something like: (trigger)speed[y]*100.0%MPH(/trigger)(effect)thrustaxis[z]*10.0%MPH(/effect)? I want it to start thrusting up at 10 mph on the z axis when the object achieves 100 mph along the y axis. Is this possible?
        CPhillips
        In next version you can store values between frames. So you could (in theory) store the position and then see how far it moved and then scale your force based on that.
        • P Offline
          physicsguy2
          Hey bear!!! wassup Chris? wassup Phillips? wassup?
          • P Offline
            Physicsguy1
            Umm... Please post that on the Newbie forum
