    Create component with a subroutine question
    4 Posts 3 Posters 399 Views 3 Watching
      shirazbj
      What I want to do is to create a component like a table. I use one same subroutine to create the four legs and the top.
      I declared a component definition in the Main like this:
      $new_comp_def=Sketchup.active_model.definitions.add("MyComp")
      then try to add some face entitites in a subroutine to it like this:
      points ...
      face=$new_comp_def.entities.add_face(points)
      face.pushpull(height)
      The error I got is some nil faces which can't be pushpulled. It seems the global virable $new_comp_def has no efect. I can't save the entities into it. Sometimes the error message says I was referencing a deleted entity.
      Are these faces deleted when the subroutine finished?
        Could you post the exact error?
        I'm wondering though, if the points you feed .add_face doesn't make up a face. Do a check if the value face has after .add_face, if it's nil, then the method failed, which leads .pushpull to fail because you are trying to pushpull a nil value.
        Btw, I'd recommend that you don't use global variables. It could interfere with other scripts. Encapsulate your script in a Module or Class and use Module/Class variables instead.
          shirazbj
          Made some changes and works now.
          It seems I have to declare one definition,add entities and place the component. After that, declare anonther component definition,....
          If I declare a few definitions at the same time, when the subroutine is called for the second component, it will report the entities has been deleted.
          • Chris FullmerC Offline
            If you are creating them all like this:
            $bad_global_variable_new_group = entities.add_group $bad_global_variable_new_group = entities.add_group $bad_global_variable_new_group = entities.add_group $bad_global_variable_new_group = entities.add_group
            The variable only points to the last one. The first 3 will be lost.
            All my Plugins I've written
