    My early attempts at rendering --pls help
    22 Posts 6 Posters 1.8k Views 6 Watching
      museummaker
      margarita anyoneHello to all,
      I have been meaning to post a few pictures of a couple of things I am working on. These wouldn’t be possible without all the helpful people and information on this site.
      Here are my wip’s, I am trying out the IRenderNxt and starting to get the hang of it in spite of not being that savvy in texturing. I seem to hit some parts really well and other parts… not so good.
      Comment, critique encouraged.
      (Solo thank you for the trees and birds!)
      bit bumpy
      in the ghetto
      • X Offline
        xrok1
        very nice 😛 , though your door could use a knob and your window textures are off center. it would look really good if you could leavbe that ammount of bump on the joints and breaks but smooth the faces a bit. you could do that if you edit the bump map a bit.
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        • X Offline
          xrok1
          i'm not certain about irender, i usually use podium, but autobump probably just uses info from the .jpg you texture with. podium and most other renderers can do this too, in podium you just rename your texture to carpet*_bump1* for example and the 1 after bump is the strength of the bump. if you want to use an actual bump map you import the bump map and make sure its named carpet*_bump1* and that the original texture is just named carpet not carpet*_bump1*.
          i'm not telling you this to confuse you but it may work similar with irender and it may give you an idea or two. the best step is probably the irender help file and search for bump.
            museummaker
            Thats the part I haven't figured out yet, I rely on autobump. This may be a dumb question but where does the bump map live? Is a PS layer? I know it is a gray scale that is dark on the "in" bumps and light on the "out" but I am not sure where I assemble the texture and bump map (2 files?) That is where I am stuck.
            Thanks for the comments, I have been thinking about the door knob...
            • X Offline
              xrok1
              here we go: http://www.renderplus.com/wk/Bump_Maps_w.htm#Standard_Bump_Maps
                museummaker
                Excellent, I looked there early on but that is what I needed to look at again.
                I found better ground textures so its not so flat looking.
                thanks again
                • X Offline
                  xrok1
                  love to see an update. 😛
                  • tinanneT Offline
                    tinanne
                    Yes, me too. Very nice.
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                      museummaker
                      Its getting better but the wall is still too bumpy bumpy for me.
                      I warmed it up a bit in PS too.
                      getting better?
                      • Al HartA Offline
                        Al Hart
                        "Autobump" in IRender uses the texture itself as a bump map. This produces interesting, but incorrect results. A true bump map is a separate image in which the grey scale represents the ins and outs of the surface. When you use an image the light and dark almost never correspond to the ins and outs of the actual material. If you happen to have a "true" bump map, then you attach both the bump map and the texture image to the same material as separate images.
                        Here is a good example. This is a "true" bump map for a stone surface.
                        http://wiki.renderplus.com/images/thumb/0/07/Stone-bump.jpg/250px-Stone-bump.jpg
                        The shades of grey represent the depth of the surface.
                        Here is the effect of applying this bump map to a cube.
                        http://wiki.renderplus.com/images/4/47/Stone2-bump.png
                        Notice how the light angle modifies the effect of the 3D depth of the bumps.
                        The "bump" image does not resemble the actual appearance of the stone at all.
                        Al Hart
                        IRender nXt from Render Plus
                          richcat
                          I see the scene is progressing very nicely
                          The image to use as bump map ie a gray scale image can be imported in the second texture position in the advanced material editor,(via advanced button) but make sure the base colour is off for the bump texture, adjust bump to suite. Here is link to accustudio with tut for auotcad version which is very similar to sketchup version.
                          Basically you would start at the third image down the page, ie Material editor which in IRendernXt, you can get to via the advanced button on the material editor.
                          The image below was created by using standard stone pavers walk from sketchup, and creating gray scale jpg images to use as sue doe bumps in PS for each.
                          The one on left bump of +2 the on on right -2.
                            richcat
                            I found another link here on additional info on bumps in IrendernXt
                              museummaker
                              Thanks everyone,
                              Straight SU for comparison.
                              • X Offline
                                xrok1
                                i actually like that one better!
                                please share your grass, its awsome.
                                  museummaker
                                  The grass was by Gaieus! it is in the warehouse here http://tinyurl.com/2k6een
                                  It looks great close up, its pretty heavy for big scenes.
                                  • X Offline
                                    xrok1
                                    why can't i see the faces of the grass in you're SU shot?
                                      museummaker
                                      You just got to get really, really, close...
                                      Plus I had the light turned down, it helps to hides things,just like in real life.
                                      • X Offline
                                        xrok1
                                        this is how mine look?
                                          museummaker
                                          I think it is a transparent png, and your machine isn't reading it as transparent.??
                                          Ever have trouble with any of the png 2d trees? (Ones not cut out?)
                                            sepo
                                            That is not .png version. Here it is.
                                            • 1 / 2
