    My early attempts at rendering --pls help
    22 Posts 6 Posters 2.2k Views 6 Watching
    • X
      xrok1
      very nice 😛 , though your door could use a knob and your window textures are off center. it would look really good if you could leavbe that ammount of bump on the joints and breaks but smooth the faces a bit. you could do that if you edit the bump map a bit.
      • X
        xrok1
        i'm not certain about irender, i usually use podium, but autobump probably just uses info from the .jpg you texture with. podium and most other renderers can do this too, in podium you just rename your texture to carpet*_bump1* for example and the 1 after bump is the strength of the bump. if you want to use an actual bump map you import the bump map and make sure its named carpet*_bump1* and that the original texture is just named carpet not carpet*_bump1*.
        i'm not telling you this to confuse you but it may work similar with irender and it may give you an idea or two. the best step is probably the irender help file and search for bump.
          museummaker
          Thats the part I haven't figured out yet, I rely on autobump. This may be a dumb question but where does the bump map live? Is a PS layer? I know it is a gray scale that is dark on the "in" bumps and light on the "out" but I am not sure where I assemble the texture and bump map (2 files?) That is where I am stuck.
          Thanks for the comments, I have been thinking about the door knob...
          • X
            xrok1
            here we go: http://www.renderplus.com/wk/Bump_Maps_w.htm#Standard_Bump_Maps
              museummaker
              Excellent, I looked there early on but that is what I needed to look at again.
              I found better ground textures so its not so flat looking.
              thanks again
              • X
                xrok1
                love to see an update. 😛
                • tinanneT
                  tinanne
                  Yes, me too. Very nice.
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                    museummaker
                    Its getting better but the wall is still too bumpy bumpy for me.
                    I warmed it up a bit in PS too.
                    getting better?
                    • Al HartA
                      Al Hart
                      "Autobump" in IRender uses the texture itself as a bump map. This produces interesting, but incorrect results. A true bump map is a separate image in which the grey scale represents the ins and outs of the surface. When you use an image the light and dark almost never correspond to the ins and outs of the actual material. If you happen to have a "true" bump map, then you attach both the bump map and the texture image to the same material as separate images.
                      Here is a good example. This is a "true" bump map for a stone surface.
                      http://wiki.renderplus.com/images/thumb/0/07/Stone-bump.jpg/250px-Stone-bump.jpg
                      The shades of grey represent the depth of the surface.
                      Here is the effect of applying this bump map to a cube.
                      http://wiki.renderplus.com/images/4/47/Stone2-bump.png
                      Notice how the light angle modifies the effect of the 3D depth of the bumps.
                      The "bump" image does not resemble the actual appearance of the stone at all.
                      Al Hart
                      IRender nXt from Render Plus
                        richcat
                        I see the scene is progressing very nicely
                        The image to use as bump map ie a gray scale image can be imported in the second texture position in the advanced material editor,(via advanced button) but make sure the base colour is off for the bump texture, adjust bump to suite. Here is link to accustudio with tut for auotcad version which is very similar to sketchup version.
                        Basically you would start at the third image down the page, ie Material editor which in IRendernXt, you can get to via the advanced button on the material editor.
                        The image below was created by using standard stone pavers walk from sketchup, and creating gray scale jpg images to use as sue doe bumps in PS for each.
                        The one on left bump of +2 the on on right -2.
                          richcat
                          I found another link here on additional info on bumps in IrendernXt
                            museummaker
                            Thanks everyone,
                            Straight SU for comparison.
                            • X
                              xrok1
                              i actually like that one better!
                              please share your grass, its awsome.
                                museummaker
                                The grass was by Gaieus! it is in the warehouse here http://tinyurl.com/2k6een
                                It looks great close up, its pretty heavy for big scenes.
                                • X
                                  xrok1
                                  why can't i see the faces of the grass in you're SU shot?
                                    museummaker
                                    You just got to get really, really, close...
                                    Plus I had the light turned down, it helps to hides things,just like in real life.
                                    • X
                                      xrok1
                                      this is how mine look?
                                        museummaker
                                        I think it is a transparent png, and your machine isn't reading it as transparent.??
                                        Ever have trouble with any of the png 2d trees? (Ones not cut out?)
                                          sepo
                                          That is not .png version. Here it is.
                                          • X
                                            xrok1
                                            thanks thats better. i wonder why the 3Dwarehouse one doesn't have the .png in it?
