    Problem with UVHelper
    3 Posts 2 Posters 453 Views 2 Watching
    • S
      spring.freediver
      When I try to experiment with UVHelper using this code"
      ` require 'sketchup.rb'
      def uvhelp
      face=Sketchup.active_model.selection[0]
      tw = Sketchup::TextureWriter.new
      uvHelp = face.get_UVHelper true, true, tw
      pts = []
      i = 0
      face.outer_loop.vertices.each do |vert|
        pts[i] = vert.position
        pts[i+1] = uvHelp.get_front_UVQ(vert.position)
        i = i+2
      prompt = ["P1","UV1",
            "P2","UV2",
            "P3","UV3",
            "P4","UV4"]
      defaults = [pts[0], pts[1], pts[2], pts[3], pts[4], pts[5], pts[6], pts[7]]
      results = inputbox prompt, defaults, name
      if( not file_loaded?("UVHelper.rb") )
      UI.menu("Plugins").add_item($exStrings.GetString("UVHelper")) { uvhelp }
      file_loaded("UVHelper.rb")`
      I get this error message:
      Error: #<TypeError: wrong argument type (expected Sketchup::TextureWriter)>
      C:/Program Files/Google/Google SketchUp 6/Plugins/UVHelper.rb:8:in get_UVHelper' C:/Program Files/Google/Google SketchUp 6/Plugins/UVHelper.rb:8:in uvhelp'
      C:/Program Files/Google/Google SketchUp 6/Plugins/UVHelper.rb:26
      C:/Program Files/Google/Google SketchUp 6/Plugins/UVHelper.rb:26:in `call'
      It doesn't even like the call to face.get_UVHelper, which is straight from the examples.
      • thomthomT
        That's odd. Typeing into the Ruby console I get the same error.
        But I have used the same code in one of my own plugin and that works. I can't see what the difference might be.
        • thomthomT
          Ah! I see it now.
          Use tw = Sketchup.create_texture_writer instead of tw = Sketchup::TextureWriter.new.
          I'll add it to the list of errors in the manual: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17047
