    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    You won't believe it.. but it is true :)
    33 Posts 17 Posters 1.6k Views 17 Watching
      tomasz
      Surprise! This thread is related to ... a science.
      This is really amazing. Read the information and good luck,
      you will need it. This will drive people crazy for hours.
      If you see this lady turning in clockwise you are using your right brain.
      If you see it the other way, you are using left brain.
      Some people do see both ways, but most people see it only one way.
      See if you can make her go one way and then the other by shifting the brain's current. BOTH DIRECTIONS CAN BE SEEN
      Experimentation has shown that the two different sides, or hemispheres of the brain are responsible for different manners of thinking. The following table illustrates the differences between left-brain and right-brain thinking:
      Left Brain - Logical-Sequential-Rational-Analytical-Objective, looks at parts
      Right Brain - Random-Intuitive-Holistic-Synthesizing -Subjective, looks at wholes
      Most individuals have a distinct preference for one of these styles of thinking. Some, however, are more whole-brained and equally adept at both modes. In general, schools tend to favour left-brain modes of thinking, while downplaying the right-brain activities. Left-brain scholastic subjects focus on logical thinking, analysis, and accuracy. Right-brained subjects, on the other hand, focus on aesthetics, feeling, and creativity.
      If you look away, she may switch from one direction to the other.
      I have verified the thing in two ways:
      1. I have opened the GIF in animation editor to make sure there is no faking. The gif contains 34 frames in a closed loop.
      2. I and my wife we have looked at the image at the same time. She has seen the lady spinning anticlockwise and I have seen her spinning clockwise! We have discovered that the both visions has been synchronized and that the lady' foot was always at the same time on the left hand side of the image, just rotation didn't match for a minute or so, then my wife started to see the lady spinning in the same direction as mine ๐Ÿ˜„
      Very interesting. It is like a test.... are you in a CREATIVE or in ANALYTIC mood?
      I cannot switch my brain purposely, but I see both directions without big problem. When I am more relaxed it is easier for me to use right hemisphere ๐Ÿ˜„
      It is like in 'The Matrix' ... is it the spoon bending or your mind?
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • jeff hammondJ Offline
        jeff hammond
        this came up last year :
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=179&t=5866
        complete with a poll and all sorts of methods for switching the rotation ๐Ÿ˜„
        dotdotdot
          Aidus
          Well I see both directions ๐Ÿ‘Š
          CPU: Intel Core i7 Extreme Edition 965
          RAM: OCZ Gold DDR3 1600MHz 12Gb
          Video: Asus Radeon HD4870 X2 2Gb
          Mobo: Asus P6T Deluxe 1366 Intel X58
            tomasz
            Jeff, thanks for the link.
            The original direction stored in GIF is left (counterclockwise).
            In order to achieve right direction a brain has to be creative.
            I don't think the shadow is a key to switching directions... at least it doesn't work for me.
            Neither tricks with a mouse.
            The figure is asymmetrical..
            A brain has to play the frames in opposite direction...? then... if should always start first spin in a stored - left direction.. but it doesn't!
            Is it just a trick of a mind? I haven't found an explanation on the company website...
              Only Right ๐Ÿ’š
              Edit : Left now ๐Ÿ˜ฎ
              I use the mousewheel updown quickly then release!
              Terrific effect! ๐Ÿ˜ฒ If it's not a fake, our brain is a true liar ๐Ÿ’š
              • MALAISEM Offline
                MALAISE
                You're experiencing how our brain "works" ( As far as It's a part of ourself!) New cognition science branch:
                how to explore conscience and explain magical illusions.... ๐Ÿ‘
                MALAISE
                La Connaissance n'a de valeur que partagรฉe
                • N Offline
                  notareal
                  Funny, first look do gives me clock wise rotation, but just a brief concentration to the image turns rotation to counter clock wise and the if I turn my concentration to the text the animation starts running with clock wise rotation again. This is a keeper, thanks.
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                  • F Offline
                    FenS
                    What lady? I only see a Rorschach-butterfly ๐Ÿ˜„
                    Really like this one and the same for me, the direction of spinning changes when I am looking at the lady or when I am reading the text below her.
                    Quรฉ sais je? there is still so much to be learned...
                      sintra
                      Hi Tomasz,
                      Really cool post very interesting and addictive.
                      At first i saw it anti clockwise, i looked away then all i see is her going clockwise and its been like that since arghhhhh ๐Ÿ˜† ๐Ÿ˜†
                        BTM
                        I can see it either way if I want to. I even tried to see if I could get it to do half turns and reverse, So it looks like it's facing away, then does a half turn and faces you, then another half turn the other direction, and faces you again, as if it had never changed. and it worked. Creepy... ๐Ÿ˜ฒ
                        • AnssiA Offline
                          Anssi
                          This demonstrates our utter failure to see it as a 2D shape. I got this illusion even in the real world when I sat waiting for a plane. On the opposite side of the runway a radar antenna was spinning, silhouetted against the sky. It was quite easy to make it "shift direction".
                          Anssi
                            sorgesu
                            This is wild. I can actually take note of the second she changes direction. There is hiccup. A suspended moment when she seems to pause and then she changes direction.
                            When I first looked at her, she was consistently going counter clockwise. After a while she suddenly changed direction and I couldn't force the counter clockwise again. Until I started reading the text and then she reversed. It seems that when I first looked at her, I was 'analyzing' the situation. Then when I understood the situation, I automatically switched to right brain mode. Once I read, I was back into left brain. If I looked up at her again, she would switch and go clockwise. Wow.
                            Susan Sorger
                              It's not a default of the "Windows viewer" or a default of the "Navigator viewer"? ๐Ÿ˜‰
                              • pbacotP Offline
                                her posture is for a clockwise direction. Is that part of the visual cues your left brain is using? Dancers commonly lead with their head and outstretched hand.
                                So far I can see the other direction with it upside down but it goes back to clockwise when I turn it at all back towards right side up.
                                EDIT: I had it all wrong. When you see her go either way it looks like the same posture. Once I saw her going counterclockwise, I couldn't go back it seems.
                                  Aidus
                                  She is not rotating at all. Just wobling from one side to other. It's hard to see but so it is.
                                    Another method ๐Ÿ˜„
                                    Blink your eyes and turn your head in the wishing turn wanted ๐Ÿ˜‰
                                      tomot
                                      I just caught a glimpse, just before she was sliding down the pole.
                                      (I gotta get that checked out soon!)
                                      [my plugins](http://thingsvirtual.blogspot.ca/)
                                      tomot
                                        sorgesu
                                        okay, I checked this out and it is totally debunked here: http://scienceline.org/2007/10/29/ask-hsu-spinning-girl-right-left-brain-hemispheres/
                                        It really has nothing at all to do with left brain/right brain perceptions at all.
                                        Anssi was completely right. It is about forcing a 3D understanding onto something that is 2D.
                                        Susan Sorger
                                          tomasz
                                          They are writing that associating left or right hemisphere of a brain with a certain activities is just a theory, which is not really true, but the fact that some people cannot see it spinning clockwise proves that it has to do something with imagination... just see the image I have prepared for you:
                                          I think that image can help those with 'one direction only' find a way to switch. Why? Take a closer look at each individual frame. I can easily see all those intermediate frames between those when the position of the lady IS certain, as a lady facing me or showing her back ๐Ÿ˜„!
                                          Our imagination decides if we see the front or the back because the silhouette doesn't define it exactly.
                                          Tomasz
                                            sorgesu
                                            so maybe you intended to mirror one of the pictures? They appear the same to me.
                                            Susan Sorger
                                            • 2 / 2
