    Background Images
    5 Posts 4 Posters 1.4k Views 4 Watching
      mrdamon
      Is it possible to place background images in a sketchUp model such as a city skyline (in the distance, I don't want to build a whole city skyline in the model)?
      mrDamon
      • E Offline
        Ecuadorian
        http://www.youtube.com/watch?v=ey0sKd5I700
        Patience. The answer if halfway through the video.
        BTW, the SketchUp channel on Youtube is an amazing place to start learning SketchUp.
        http://www.youtube.com/user/sketchupvideo?blend=3&ob=4
        -Miguel Lescano
        • honoluludesktopH Offline
          honoluludesktop
          from the SU menu select Window > Styles > watermark (select the icon with ok) > select + sign > and path to your background image. Go through the menus, and select the appearance you want. Its a good idea to dull the background with a image editor before you do this, as the view of real backgrounds are affected by the layers of atmosphere.
          • H Offline
            hebrides
            blending is part of the watermark settings. The fade or blend is visible as you change it to suit.
            The watermark is great as the guys have pointed out. It is also possible (without using the watermark) to just stand up a rectangle and place an image of a background on it, or any other 2d image you create.
              honoluludesktop
              That's right, forgot completely about that since I typically provide the background in a render. Don't forget to select SU ground with no transparency. Sorry no foreground in the example.
