    [Plugin] Components onto Faces v1.2.0 UPDATE May 23, 2013
    61 Posts 16 Posters 70.3k Views 16 Watching
      Waiting now the top Sphere collection πŸ˜„
      Maybe something like "a component onto face only if this face is bigger than..."
      • Chris FullmerC Offline
        You want it to not copy a component onto all the tiny little faces? I could write it, but I'm not sure if its universally needed by everyone. I'd hate to take away a feature that others like.
        Chris
        All my Plugins I've written
          Ahh, I think I see. Take the sphere and unsmooth all edges. Then just smoothe the top triangle faces and the bottom ones. Then run components into face collections and it will treat the top of the sphere as a single face. Then triple click on the sphere and re-smooth all the faces.
          Chris
            You say smooth, resmooth...with what tool? Maybe a Duhduh πŸ˜„
            maybe not but it's universally for the geometry and ask nothing to do for the user! (unsmooth, resmooth etc... πŸ˜‰
            For the coder that ask to calculate the surface πŸ˜„
            I don't know if it's hard or not and time consuming for the process πŸ˜’
            And that works not so good a wished but maybe I don't use the good tool for Unsmooth? ( Soften Edges ? πŸ˜‰hum.jpg
              Here is what I was thinking.
              [flash=632,573:1ubr9un9]http://www.chrisfullmer.com/forums/components_onto_faces_sphere_top.swf[/flash:1ubr9un9]
              Does that help?
              Chris
                Oh darn, I just did some more in-depth reading on "centroids" and I think I did not quite implement the triangle center finding mechanism quite right. It works in general, but I'm pretty sure there will be triangles that will still confuse it. OH well, if its really a problem the way I implemented it, I can look into fixing it. A fix will be a bit more math intensive than I wan to invest in it if possible...
                Chris
                  Yes because end of game must be something like that (not perfect just concept) πŸ˜‰
                  And avoid all users manipulations πŸ˜‰
                  • X Offline
                    xrok1
                    Chris, have you considered the copy every Nth face suggestion? it would be great if the N could be random as well with a min max value for the total copies. πŸ˜„
                    β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                    • Z Offline
                      ZFRPS
                      this good idea !
                      But...this plugin for face only.
                      If Select a single component and a series of pionts of intersection. Then run this script. It will copy that component onto all the pionts of intersection. It will ignore any faces, groups, images, etc that are in the selection set. If more than one component is selected, it will use the first one it encounters.then this plugin will is very very nice !
                      for piont of intersection same for faces .useful for everyone !
                      sketchup is bim
                      • Z Offline
                        ZFRPS
                        Dear Chris:
                        I wish your skript can put the components onto the points of intersection.
                        thanks again .
                        sketchup is bim
                        • Z Offline
                          ZFRPS
                          Dear Chris:
                             Please came in !
                                            waiting for you and love you.
                          sketchup is bim
                            rv1974
                            Chris could add 'scale component to match the face area' feature?
                            Example: I'd select the glass faces in windows made by windowizer and run your script to insert
                            the 'curtain' component. Everything works fine already except matching the component to the glazing
                            opening.
                            What do you think?
                              Its on my list to do, but it gets very complex when the shapes are not 3 sided objects fitting onto 3 sided faces, or 4 sided to 4 sided, etc. Even 4 sided is hard, because most people don't realize that their 4 sided face is often actually 2 non-planar triangles.
                              So its a functionality I would like to implement, but every time I've tried, I remember how much work it really is.
                              • ely862meE Offline
                                ely862me
                                Any idea if there is a plugin that would place parts onto a face with some added distance between the parts? Or simply put all the components at once onto a face, not just one component. I have some 3d puzzles and I would like to select all the pieces then select a face and the plugin should move all the pieces one near another onto that face, or even one over another(I would do the placing later).
                                Thanks !
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                  Try this one in developpment by CPlassais! πŸ˜‰
                                  After clicking on the receiving side as long as you did not select another face you can adjust the rotation or translation on the plane defined by the receiving side.
                                  You use the keypad Director or numeric keypad on your keyboard Arrow
                                  5 key reverses the normal of the receiving side (you avoid contortions to get the underside
                                  The + or - button to increase or decrease the increment of which is the launch of the operation of 1 or 1 unit of measurement model
                                  The home and end keys or 7 and 1 used to change the rotation
                                  The guidelines allow the 8,4,2,6 keys or translations. (not perfect at axis level shift / key)
                                  If there is not z just draw on your component a little box of the measure wanted! πŸ˜‰
                                  And kill it at the end!
                                  Tab = Multiple Copy mode
                                  http://s6.postimg.org/st2yjegy9/faces_faces7.jpg
                                  http://s6.postimg.org/czk6481ch/faces_faces4.jpg
                                  http://s6.postimg.org/cvqcnyvv5/faces_faces1.jpg
                                  • ely862meE Offline
                                    ely862me
                                    Thank you Pilou, but this is not exactly what I want. I will create another thread in order to let this one alone. The operation should work exactly as Components onto faces, but instead of pasting one component onto many faces, I want to place more components onto one face(one near another). Like when you have a cabinet and you want the pieces to be placed one near another in order to be cut with a cnc machine.
                                    • ely862meE Offline
                                      ely862me
                                      I have puzzles with many pieces, like 70, 100 or more. It will be a tedious job to do it with this plugin, I would rather rotate them in bulk, when possible, and move/place them with the move tool. I expected a plugin that works like this: Select all the components, select a face and then all the components will be automatically placed onto that face(would be awesome with some space between them) ...
                                        The plug that I posted above make also this as you can move at any place, rotate it on the surface inside the plug! πŸ˜‰
                                          So you want a puzzle helper! πŸ˜„
                                          PS
                                          How is your Puzzle ?
                                          • ely862meE Offline
                                            ely862me
                                            This kind of puzzle
                                            http://www.asia.ru/images/target/img/product/11/13/18/11131889.jpg
                                            • 3 / 4
