    [REQUEST] SU 7 to SU6
    6 Posts 5 Posters 978 Views 5 Watching
    • RayOchoaR Offline
      RayOchoa
      Is there any way i could convert all my su 7 models to su 6 files? I am wanting to un install su 7 because there is not any improvements for my workflow and i wanted to go back to 6 besides i already have the pro version and i do not wish to upgrade at this time. Please help me
      CaR DeSiGnS bY mE
      http://ray-ochoa.com
      • soloS Offline
        solo
        Depending on how many models you have really, the one way is open them up one at a time and then save as SU6 in the drop window options.
        http://www.solos-art.com
        • K Offline
          kwistenbiebel
          I have the same issue in the office.
          Often I get SU7-free models from co-workers which I can't open in my SU6 Pro.
          That forced me to install the SU7 free version as well, even when I don't use it.
          • RayOchoaR Offline
            RayOchoa
            does the sketchup Viewer work with both versions as well?
            CaR DeSiGnS bY mE
            • E Offline
              Ecuadorian
              I guess you could:
              1-Place all your SU7 files in a single folder
              2-Load that folder as a component folder from within SU7, and start placing those components like crazy in your scene
              3-Save the file with all your components as version 6
              4-Make a new folder for your converted files
              5-Open it with SU6, go to the "components" window, choose to see those "In model", and "save library as..." in the new folder.
              I guess this could save you some time. I say I guess because I have yet to test it.
              EDIT: It works. Just make sure to do it in wireframe mode or your PC will slow down to a crawl if you have lots of files to convert. And I wish there was a "place all components" sort of command to save some time.
              -Miguel Lescano
              • P Offline
                putnik
                RayOchoa, I had exactly the same problem before SU7 came out.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=1897&p=31500&hilit=+converter#p8826
                Now that I use version 7, it's not a problem for me anymore..
                DeepExploration can save into any version of SketchUp (from v3 to v7), and you can use it's batch function to convert multiple files at a time. However, it messes up texture maping of textured SU models. It costs quite a bit too, but you can use trial version for a month without restrictions. It's good in every other way though.
                http://keshas.info
