    Camera Follow Glitch
    3 Posts 3 Posters 805 Views 3 Watching
    • B
      Bryden
      I've noticed this glitch when you Right Click on an object then select Camera Follow then press the S or A keys causes the simulation to end. But if you set the camera to follow an object in scene manager this glitch doesn't happen πŸ˜•
      Here is an example model.
      SU7
      Example of this glitch
      SU6
      Sketchup 6 version
      http://img7.imageshack.us/img7/8487/googlesketchupuserbarzh3.jpg
      • B
        BTM
        Bryden, that is not a glitch. the reason this happens is because, when you have the sketchup window selected, the A and S keys are shortcuts to the Arc and Scale tools. next time you click "follow" on an object, make sure to select the control panel before using these keys.
        • C
          CPhillips
          Yeah, BTM is right.
