    Intuitiv "Nurbs" software
    11 Posts 6 Posters 3.1k Views 6 Watching
    • MALAISEM
      MALAISE
      Hi All
      Browsing the web,to find a way to simulate organic form, I've found this:
      http://www.cbmodelpro.com/
      It's a beta release, possibility to get a key for unlimited use. Very intuitiv UI
      after a short discovery, I exported *.obj into SU without any restriction ( may have to be rescaled)
      Here a short test :
      Enjoy
      MALAISE 👍 👍
      os:  a bone, ein Knochen
        You say Nurbs, I don't believe that it is 😄
        It's just "Zbrush like" Subdivision modeler only polygonic 😉
        Maybe you must change the title 😉
        The more intuitive Nurbs modeler is MOI yes 💚
        • MALAISEM
          MALAISE
          Hi Pilou
          You're right, but as far as SOLIDWORKS is behind....Let's try it
          I've changed a little bit the subject 😎
          MALAISE 💚
            The quality of the approximation (mesh density) can be changed by the Lo, Med, and Hi buttons.
            That can't be nurbs! 💚
            • jeff hammondJ
              jeff hammond
              i'm not sure if i have a use for this but it's definitely the easiest piece of software i've ever come across for making these types of shapes.. i didn't read the manual and was drawing some crazy looking shapes in a matter of minutes..
              so yes, it's intuitive... thanks for sharing..
              attn: mac users... there's a version for you too 🙂
              dotdotdot
              • J
                johnsenior1973
                Just played around with it a few minutes and have to say I like it a lot so far. Kind of like an SU version of ZBrush. Good find.
                • MALAISEM
                  MALAISE
                  Thanks for reply John, Jeff... 😄
                  Pilou, I've downloaded MoI, and I'll play with it soon. Would you define what Nurbs are ? I guess I misunderstand the concept. 😳
                  MALAISE 😄
                  • R
                    remus
                    Good succinct description form wikipedia: Non-uniform rational B-spline (NURBS) is a mathematical model commonly used in computer graphics for generating and representing curves and surfaces.
                    So basically they are a way of using maths to describe shapes and surfaces.
                      @ Malaise
                      En 2 mots 😄
                      Permettent toutes opérations booléennes avec résultats parfaits sans "polygonisation"
                      Permettent tous agrandissements d'échelles parfaits sans "polygonisation"
                      Et évidemment toutes sorties graphiques au traits parfaits
                      Idéales pour tout ce qui est usinage de pièces "mécaniques"
                      Ne sont pas idéales pour tout ce qui est "organique"!
                      (il faut bien qu'il reste quelques choses aux polygones de subdivision 😄
                      Les 2 concepts de création : propagations de courbes sur d'autres courbes = surfaces ou volumes
                      Ajout / soustraction de volumes en continu
                      Voilà en gros 💚
                      PS en termes de poids de fichiers : négligeable car objets définis par formules mathématiques
                      http://www.zbrushcentral.com/zbc/attachment.php?attachmentid=42025
                      http://www.zbrushcentral.com/zbc/attachment.php?attachmentid=42020
                      http://forums.polyloop.net/imagehosting/19645f487eeb5456.jpg
                      • MALAISEM
                        MALAISE
                        Yeah, Thanks Remus for playing attention to my question. 👍
                        I made a bit confusion with working on organic shapes.
                        Pilou,
                        Réponse complète et précise, effectivement je faisais une confusion quant aux applications.... en un mot les Nurbs sont des surfaces ou volumes mathématiquement paramètrables.
                        Merci M'sieur et je pense ne pas être le seul à qui cela rende service. 😄
                        MALAISE
                        • E
                          Ecuadorian
                          Thank you very much for the heads up, Malaise.
                          These are exciting times for the 3D world, with so many new programs being developed.
                          -Miguel Lescano
