    Send string value to Webdialog
    7 Posts 4 Posters 566 Views 4 Watching
    • P Offline
      Pout
      This is how it can be done (besides JSON)
      Example.
      In ruby
      name="blablabla"
      command = "_showdata('taskname', '#{name}')"
      dialog.execute_script(command)
      In webdialog
      function _showdata(id,value) {
      	var element = document.getElementById(id);
      	element.value = value;
      The only problem i have is:
      Ruby continues interpreting script without waiting.
      For example: if the dialog is not yet open, you test on that and first open the dialog, the value will not be shown in the dialog. App. the ruby script just continues without waiting tille the dialog is open. Now if i place a UI.messagebox just before the command line all goes well.
      Is there any way to hold the ruby script so it only continues if the dialog script is executed? Or is there another way to do this?
        I suppose you could make up an array of commands that would stack up if the webdialog isn't open. Then, when it does loop through and send them.
          Jim
          Maybe use the show{} method to defer execution?
          dlg = WebDilaog.new(...)
          dlg.show {
            # your code here
          • chrisglasierC Offline
            chrisglasier
            If you are going to open a web dialog I would recommend you always control the action from the dialog's javascript - onload call ruby callback > receive ruby execute script.
            Chris
            With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
            • P Offline
              Pout
              Hey Chris,
              Do you have an example for me?
              Thanks!
                chrisglasier
                Open transformations.zip from here.
                Let me know if you have any problems.
                Chris
                edit: in my last post there
                • P Offline
                  Pout
                  ok i'll look into it πŸ˜„
                  Thanks!
