    'Error Loading File progressbar.rb' problem
    5 Posts 3 Posters 1.2k Views 3 Watching
      maxel99
      Recently installed sk07 on new comp and put my ruby plugins in the right folder and got this message, any ideas?
      cannot convert nil into StringError Loading File SimplifyContours.rb
      cannot convert nil into StringError Loading File SoapSkinBubbleTools.rb
      cannot convert nil into StringError Loading File utilities.rb
      cannot convert nil into StringError Loading File weld.rb
      cannot convert nil into StringError Loading File dynamiccomponents.rb
      cannot convert nil into StringError Loading File extensions.rb
      cannot convert nil into StringError Loading File langhandler.rb
      cannot convert nil into StringError Loading File make_pano_pm.rb
      cannot convert nil into StringError Loading File sandboxtools.rb
      cannot convert nil into StringError Loading File sketchup.rb
      cannot convert nil into String'
      • Chris FullmerC Offline
        Odd, this is the 4th post with very similar problems in the last 2 or 3 days. So far they have all been copying minor errors. Here is a link to one from a day or two ago with identical symptoms. I think it will help:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16852
        Chris
        All my Plugins I've written
        • I Offline
          iam_doss
          Hi, do someone knows which commands adds "make_pano_pm.rb" in SketchUp or how is it used?
          %(#000080)[Ignacio Arrúe
          Arquitecto
          OpenCartis, S.L.]
            It is not a complete, functioning ruby. I'm not sure why its inlucded.
            There is a panoramic exporter you can use, found here:
            (www.smustard.com)
            Hope that helps,
            Chris
            • I Offline
              iam_doss
              Thank you Chris
              Arquitecto
              OpenCartis, S.L.]
