    Does SP3 still allow for objects to copy themselves?
    3 Posts 3 Posters 901 Views 3 Watching
    • P Offline
      Platypus5
      I remember a while ago Chris said that objects will be able to rapidly copy themelves with the push of a button. I don't mean the "copy body" thing. I was told that there was a code you could put in an object which told it to copy itself, when to, and in what direction...
      Is that still in there?
        Sgal
        I asked a similar question and itseems to be incompatible with SketchyReplay.
        by CPhillips on Tue Feb 10, 2009 4:26 am
        Sgal wrote:I saw a video of SketchyPhysics 3 showing a piston linked to a normal cylinder. When activate the corrispondent slider, the cylinder seems to multiply.Is that possible in the current version?
        http://www.youtube.com/watch?v=vNlhGt32oBg&eurl=http://sketchuptips.blogspot.com/2008/09/sketchyphysics-3-preview-video.html&feature=player_embedded
        That feature isn't in yet. I have to figure out how to make it work with replay.
        Then I downloaded the video with enough resolution to read the code and tried to use it (after some modifications). Obviously it didn't work.
        That is all I know about this point.
          CPhillips
          I fixed the issue with Replay but I still haven't figured out how to expose the feature.
