    Last tool recall?
    6 Posts 5 Posters 1.1k Views 5 Watching
    • EarthMoverE Offline
      EarthMover
      Is there such a ruby? One that will allow you to use a shortcut to recall the last tool you were using so that when you switch to select mode, you can bounce right back to the prior tool? It would be more convenient than adding and remembering shortcuts for all my tools.
      Content Creator at Skapeup
        jmmad
        +1 For that Earthmover
        that would be great and more usefull if could be done with a right click when nothing is selected
        Get Upa !
        • W Offline
          wikii
          Sutool allow user use several_keys as a shortcut , also allow user press a key to load last used tool.
            jmmad
            that sounds exelent wikii, but where can i get that plugin?
            Get Upa !
              A cool way could be that if you press (and hold) the Space bar, it would only temporarily switch to the select tool (as long as you keep it pressed) and when released, it would change back to the tool previously used.
              Just hitting the space bar would select the select tool as now.
              Computers should be able to make a distinction between the two ways of using it but I doubt that this could be coded into ruby. 😞
                Matt666
                Please take a look here! πŸ˜‰
                Frenglish at its best !
                My scripts
