    2.5D Conifers...?
    5 Posts 3 Posters 981 Views 3 Watching
      tomsdesk
      Took a break from the tree mill (making trunks is tedious fun :`) and made these little experiments: any interest in any or all of them as a set of different sizes and shapes?
      2.5D Trees & Shrubs!
        bubbalove
        I like 'em Tom! The bigger the set the better...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
          tomsdesk
          Glad to hear that, David...what's taking so long putting a package out is I'm working on sets of trees using the same leaf png, but in at least 6-8 different sizes and shapes: from suckers to taller than some will use as-is (ie. real size mature).
            mirjman
            tom, I just posted this on the thread about solo's garden package as well, but I thought it would be of interest to you since you are dealing with the same issues,
            404 Not Found
            (www.sketchucation.com)
            a good discussion about containers and processor usage
              tomsdesk
              Yeah, I just noticed that, Mirjman...thanks. I have to make a single image into a component in order to allow SU to change the color: but since some of the render apps need the images exploded, I'm going to test using a png material instead of an unexploded image...then I can get rid of all the components inside the group of leaf faces. I'll test if this is faster with a hundred or so trees.
