    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Showing new geometry as its made?
    11 Posts 3 Posters 948 Views 3 Watching
    • Chris FullmerC Offline
      Hi, Ive written an incredible script (teeheehee) that makes groups of geometry. It makes a few hundred , but I'd like to be able to see them as they are made. IS there a way to refreshy the view or something after each one is made?
      Chris
      All my Plugins I've written
        Matt666
        Sketchup.active_model.active_view.invalidate
        Frenglish at its best !
        My scripts
          I have a method that makes and randomly places a group and it has a small delay forced in their. So I have that method called in a loop for 100 times. In between calling that method I inserted your code. It didn't work for me. I still only see all the groups after the entire script is run. Did I put it in right?
          Chris
            Oh dear!, I'll look into the Tool class creation. I'm at school all day and I'm not supposed to be working on scripts because I have a big presentation on Wednesday ๐Ÿ˜ž So maybe if I get my work done for class I'll work on this, and possibly post my script for some pointers tonight or tomorrow. Thanks Matt and Todd,
            Chris
              todd burch
              Chris, you have to define a Tool class of tool. When you create a Tool, you have to create certain methods that will be called by SketchUp at the appropriate times. One of those is "draw".
              After you create a Tool, then you get access to methods like view.invalidate.
              Todd
              (edit: said simpler, your Tools' method "draw" will be called when one of your other methods issues view.invalidate)
                todd burch
                Chris, I was incorrect. It's not a Tool class you need, it's an Animation Class. However, you should be able to embed this functionality into your script, whether it is a Tool or not.
                I felt so bad about giving you wrong information, I wrote an example for you ๐Ÿ˜ฎ
                Todd
                require 'sketchup.rb'
                class MiniTool
                def initialize
                	@p1 = Geom;;Point3d.new ;
                	@p2 = Geom;;Point3d.new ;
                	@p3 = Geom;;Point3d.new ;
                	@p4 = Geom;;Point3d.new ;
                	@face = nil ;
                	@count = 20 ;
                end ;
                def nextFrame(view)
                	if (@count==0) then
                		@face.erase! ;
                		Sketchup.active_model.active_view.animation = nil
                		Sketchup.active_model.select_tool nil ;
                		return ;
                	end;
                	if (@count %2 ==0) then
                		@face.erase! if @face ;
                		x = rand(100) ;
                		y = rand(100) ;
                		x = -x if rand(10) > 5 ;
                		y = -y if rand(10) > 5 ;
                		z = 0 ;
                		@p2.x = x ;
                		@p3.x = x ;
                		@p3.y = y ;
                		@p4.y = y ;
                		@face = Sketchup.active_model.entities.add_face(@p1,@p2,@p3,@p4) ;
                		Sketchup.active_model.active_view.zoom_extents ;
                	else
                		@face.reverse!
                		@face.material = 'red'
                	end ;
                	sleep(0.5) ;
                	view.show_frame
                	@count -= 1 ;
                end  # nextFrame
                end ; # class MiniTool
                class AnimatedToolExample
                def initialize
                	Sketchup.active_model.active_view.animation = MiniTool.new
                end # class AnimatedToolExample
                if !file_loaded?(__FILE__) then
                	UI.menu("Tools").add_item("Animated Tool") { Sketchup.active_model.select_tool AnimatedToolExample.new }
                file_loaded(__FILE__)
                  Sweet!, Todd you rock. thanks for the example. I'll look it over and hopefully get it into my script soon (depending on class work). All this is for a Valentine's Ruby - I think I might not get it released by my target date..... lol
                  Chris
                    Its like you can read my mind! That is frighteningly close to what I am trying to achieve, a huge thanks!
                    Chris
                      ok, lots of questions. Answer what you have time for ๐Ÿ˜„
                      So I've noticed from your example:
                      This selects a tool. And the AnimatedToolExample is considered a tool because it is defined as a class and it is actived with the "Sketchup.active_model.select_tool"? Is there anything else that makes it a tool? just that its a class and is called with the .select_tool method, right?
                      Also, inside the AnimatedToolExample class, there is a single method named "initialize". But there is nothing that calls the method. I expected to see a line like calling that method or else I thought it would not ever be invoked.
                      As I'm working through the example, I see that you don't call any of the methods the way I thought they had to be called. I thought you would need a line outside the method, but inside the class that would specify which method to initialize. I've never worked classes yet. If you call a class, does it automatically run through all the methods inside of it?
                      Also, the sleep method. I think that is what I was looking for. I made a way to "pause" the script using the system clock and a while statement. But Tavi pointed out that my method would freeze up Ruby entirely. So does sleep only freeze up this specific process then? Could I also run another ruby script without it being affected by the sleep in this script? That is what I think I understood in reading through the rDoc of the sleep method.
                      LASTLY. I ran it in SU6 at school just fine. But now in SU7 at home its splatting right after it makes the first face, but before it reverses the face. I'll see if I can degub it, but I wouldn't count on it ๐Ÿ˜„
                      Thanks Todd,
                      Chris
                        todd burch
                        Yes.
                        Anything else? No. Yes in that it's activated as you say. Tools have predefined methods that are called by SketchUp in a "callback" fashion if they are defined. Methods like "onLButtonDown" for on Left Mouse button down. So, if you want an interactive tool that is aware of mouse clicks, then you need a Tool. Note that the target of .select_tool doesn't have to be a class. It could be a class method too. (for example ....select_tool MyClass.mymethod )
                        Ruby Class Operation 101. Any class that gets instantiated, always get its "initialize" method called. In other Object Oriented programming terms, the "initialize" method is the class's "constructor".
                        You need to read up on classes. Programming with Ruby under SketchUp, with all the other scripters out there (here), you really need to encapsulate your scripts inside a class or module. Read the "warning to developers" sticky thread.
                        No. You really don't ever "call a class". You instantiate a class and calls its methods on an instance of that class. As mentioned above, the initialize method of the class is called by Ruby for you when you instantiate a class.
                        Correct. You might be pausing the script, you are pegging the CPU @ 100% while you are doing it.
                        Sleep blocks (block is the correct term, not "freezes") this thread. Sleeps causes the thread to go into a wait state until the sleep timer pops (expires).
                        Theoretically, yes. However, the way Google implemented the Ruby API, it's all under a single thread, so once that thread is put to sleep, you can do nothing else. If there were multiple threads, then one could sleep while another continued to work.
                        Sounds like a bug. I wrote this on SU 6.
                        Thanks Todd,
                        Chris
                        Welcome. ๐Ÿ˜„
                          Todd, thanks for the details! Very enlightening. And to put your mind at ease, I have been using modules to encapsulate my scripts. So there should be no namespace conflicts. I was unaware that any method defined as "initialize" will be called automatically. That is cool, and very good to know. And that exaplins how the methods were being called. All in all very informative and thanks for taking the time to respond to each question - there werew quite a few!
                          Chris
