    Showing new geometry as its made?
    11 Posts 3 Posters 1.2k Views 3 Watching
      Matt666
      Sketchup.active_model.active_view.invalidate
      Frenglish at its best !
      My scripts
      • Chris FullmerC
        I have a method that makes and randomly places a group and it has a small delay forced in their. So I have that method called in a loop for 100 times. In between calling that method I inserted your code. It didn't work for me. I still only see all the groups after the entire script is run. Did I put it in right?
        • Chris FullmerC
          Oh dear!, I'll look into the Tool class creation. I'm at school all day and I'm not supposed to be working on scripts because I have a big presentation on Wednesday ๐Ÿ˜ž So maybe if I get my work done for class I'll work on this, and possibly post my script for some pointers tonight or tomorrow. Thanks Matt and Todd,
          • T
            todd burch
            Chris, you have to define a Tool class of tool. When you create a Tool, you have to create certain methods that will be called by SketchUp at the appropriate times. One of those is "draw".
            After you create a Tool, then you get access to methods like view.invalidate.
            Todd
            (edit: said simpler, your Tools' method "draw" will be called when one of your other methods issues view.invalidate)
            • T
              todd burch
              Chris, I was incorrect. It's not a Tool class you need, it's an Animation Class. However, you should be able to embed this functionality into your script, whether it is a Tool or not.
              I felt so bad about giving you wrong information, I wrote an example for you ๐Ÿ˜ฎ
              Todd
              require 'sketchup.rb'
              class MiniTool
              def initialize
              	@p1 = Geom;;Point3d.new ;
              	@p2 = Geom;;Point3d.new ;
              	@p3 = Geom;;Point3d.new ;
              	@p4 = Geom;;Point3d.new ;
              	@face = nil ;
              	@count = 20 ;
              end ;
              def nextFrame(view)
              	if (@count==0) then
              		@face.erase! ;
              		Sketchup.active_model.active_view.animation = nil
              		Sketchup.active_model.select_tool nil ;
              		return ;
              	end;
              	if (@count %2 ==0) then
              		@face.erase! if @face ;
              		x = rand(100) ;
              		y = rand(100) ;
              		x = -x if rand(10) > 5 ;
              		y = -y if rand(10) > 5 ;
              		z = 0 ;
              		@p2.x = x ;
              		@p3.x = x ;
              		@p3.y = y ;
              		@p4.y = y ;
              		@face = Sketchup.active_model.entities.add_face(@p1,@p2,@p3,@p4) ;
              		Sketchup.active_model.active_view.zoom_extents ;
              	else
              		@face.reverse!
              		@face.material = 'red'
              	end ;
              	sleep(0.5) ;
              	view.show_frame
              	@count -= 1 ;
              end  # nextFrame
              end ; # class MiniTool
              class AnimatedToolExample
              def initialize
              	Sketchup.active_model.active_view.animation = MiniTool.new
              end # class AnimatedToolExample
              if !file_loaded?(__FILE__) then
              	UI.menu("Tools").add_item("Animated Tool") { Sketchup.active_model.select_tool AnimatedToolExample.new }
              file_loaded(__FILE__)
              • Chris FullmerC
                Sweet!, Todd you rock. thanks for the example. I'll look it over and hopefully get it into my script soon (depending on class work). All this is for a Valentine's Ruby - I think I might not get it released by my target date..... lol
                • Chris FullmerC
                  Its like you can read my mind! That is frighteningly close to what I am trying to achieve, a huge thanks!
                  • Chris FullmerC
                    ok, lots of questions. Answer what you have time for ๐Ÿ˜„
                    So I've noticed from your example:
                    This selects a tool. And the AnimatedToolExample is considered a tool because it is defined as a class and it is actived with the "Sketchup.active_model.select_tool"? Is there anything else that makes it a tool? just that its a class and is called with the .select_tool method, right?
                    Also, inside the AnimatedToolExample class, there is a single method named "initialize". But there is nothing that calls the method. I expected to see a line like calling that method or else I thought it would not ever be invoked.
                    As I'm working through the example, I see that you don't call any of the methods the way I thought they had to be called. I thought you would need a line outside the method, but inside the class that would specify which method to initialize. I've never worked classes yet. If you call a class, does it automatically run through all the methods inside of it?
                    Also, the sleep method. I think that is what I was looking for. I made a way to "pause" the script using the system clock and a while statement. But Tavi pointed out that my method would freeze up Ruby entirely. So does sleep only freeze up this specific process then? Could I also run another ruby script without it being affected by the sleep in this script? That is what I think I understood in reading through the rDoc of the sleep method.
                    LASTLY. I ran it in SU6 at school just fine. But now in SU7 at home its splatting right after it makes the first face, but before it reverses the face. I'll see if I can degub it, but I wouldn't count on it ๐Ÿ˜„
                    Thanks Todd,
                    • T
                      todd burch
                      Yes.
                      Anything else? No. Yes in that it's activated as you say. Tools have predefined methods that are called by SketchUp in a "callback" fashion if they are defined. Methods like "onLButtonDown" for on Left Mouse button down. So, if you want an interactive tool that is aware of mouse clicks, then you need a Tool. Note that the target of .select_tool doesn't have to be a class. It could be a class method too. (for example ....select_tool MyClass.mymethod )
                      Ruby Class Operation 101. Any class that gets instantiated, always get its "initialize" method called. In other Object Oriented programming terms, the "initialize" method is the class's "constructor".
                      You need to read up on classes. Programming with Ruby under SketchUp, with all the other scripters out there (here), you really need to encapsulate your scripts inside a class or module. Read the "warning to developers" sticky thread.
                      No. You really don't ever "call a class". You instantiate a class and calls its methods on an instance of that class. As mentioned above, the initialize method of the class is called by Ruby for you when you instantiate a class.
                      Correct. You might be pausing the script, you are pegging the CPU @ 100% while you are doing it.
                      Sleep blocks (block is the correct term, not "freezes") this thread. Sleeps causes the thread to go into a wait state until the sleep timer pops (expires).
                      Theoretically, yes. However, the way Google implemented the Ruby API, it's all under a single thread, so once that thread is put to sleep, you can do nothing else. If there were multiple threads, then one could sleep while another continued to work.
                      Sounds like a bug. I wrote this on SU 6.
                      Thanks Todd,
                      Welcome. ๐Ÿ˜„
                      • Chris FullmerC
                        Todd, thanks for the details! Very enlightening. And to put your mind at ease, I have been using modules to encapsulate my scripts. So there should be no namespace conflicts. I was unaware that any method defined as "initialize" will be called automatically. That is cool, and very good to know. And that exaplins how the methods were being called. All in all very informative and thanks for taking the time to respond to each question - there werew quite a few!
